Modlist: Ford sierra cosworth 2wd (auto parduotas)
cosworth
Post by cosworth »
1988 metu
Engine:
200 Cosworth block ( 4WD )
Garrett GT28RS new
FORGE -31 wastegate actuator
RS 500 Intercooler core 600x400x50mm, in/out 3
Silicone hoses 3"
Custom 3" straight free flow stainless steel exhaust
Exhaust mounts - poly-x
Green filter dn 80
BOSCH light blue 400 injectors (437cc/min@3bar)
3 bar WEBER map sensor
18 psi , 310 HP ir 390 NM
Suspension:
Front: Motorcraft shock absorbers
Coilover suspension kit
7" x 450 lbs
Polurethane suspension bushes
Scorpio control arms
Scorpio steering rack
Rear: Koni sport shock absorbers
7" x 325 lbs
Body:
Front strut bar
Rear strut bar
Brakes:
Standart
Front 283 mm x 4 pot
Rear 273 mm
Hydraulic wilwood handbrake kit
Other:
Standard borg warner t5 with quickshift
Air/fuel ratio meter
Oil pressure gauge
Oil temperature gauge
Boost gauge
Sabelt racing seat
Schroth 3 point harness
Ford sierra cosworth 2WD 2.0 16V turbo
GT28rs, IC 500, Polybushes , coilover
cosworth
Re: Modlist: Ford sierra cosworth 2wd
Post by cosworth »
kelios foto is projektu
cosworth
Post by cosworth »
2
cf
Post by cf »
rekomenduociau oro filtra atskirti nuo variklio skyriaus, kad trauktu kuo maziau karshto oro.
cosworth
Post by cosworth »
bus atskirta , projektas dar nera pabaigtas iki galo :wink:
cf
Post by cf »
su laiku isitikinsi, kad "projekto" neimanoma pabaigt, ji imanoma tik nutraukt.
:twisted: :lol:
cosworth
Post by cosworth »
cf wrote:su laiku isitikinsi, kad "projekto" neimanoma pabaigt, ji imanoma tik nutraukt.
:twisted: :lol:
tas teisybe 8) , as turejau galvoj projektas su turba susijes dar nera visiskai isbaigtas , like kelios smulkmeneles :wink:
cosworth
Post by cosworth »
Keiciam Bosch light blue 400 ( 437 cc/min / 3 bar ) i Bosch grey 403 ( 503 cc/min / 3 bar )
cosworth
Post by cosworth »
vnz rezultatas prie 1.3 bar , 310 Hp ir 390 Nm
cosworth
Post by cosworth »
under the bonnet
Todo2
Post by Todo2 »
cosworth wrote:vnz rezultatas prie 1.3 bar , 310 Hp ir 390 Nm
saunu ;) iki kiek standarto viduriai laiko?
rs13
cosworth
Post by cosworth »
Cia is straipsnio vieno , kiek teisybes nezinau :
Approximate standart component power potential:
Crank: - 600bhp+
Pistons: - 500bhp + ( idealy will need maching for lower compression : or use race fuel )
Rods: - 600bhp+
Block: 2wd - 400bhp+, RS500 / 4WD -800bhp+
Exhaust manifold: 2WD - 600bhp+, 4WD- 400bhp
Inlet manifold: 2WD-400bhp, 4WD-450bhp, small turbo Escort cosworth 500bhp+, RS500-700bhp
Intake pipework: 600bhp+
Airbox: 400bhp, RS500-550bhp
Fuel pump: Sierra 400 bhp, escort 350bhp
Unmodified cylinder head: 450bhp
how come kad nera mafo? cia sitas punktas kazka turi bendro 3 bar WEBER map sensor?
cosworth
Post by cosworth »
nelabai supratau klausimo
driver wrote:how come kad nera mafo? cia sitas punktas kazka turi bendro 3 bar WEBER map sensor?
standarte MAP'as nu....
cosworth
Post by cosworth »
thanks Minde_Kei
standartas 2bar buna , pas mane buvo 2.5 bar , bet suzinojau tik tada kai pasiemiau 3 bar :lol:
s3Th
Post by s3Th »
tokia sakyciau pikta sierra :twisted:
[auto::. aves]
prekyba-remontas-diagnostika
8 652 99720
4fun
Post by 4fun »
nei MAF'o, nei lambda zondo nera.... :lol: 8) tik keli dacikai ir MAP sensorius.
live the dream
cf wrote:rekomenduociau oro filtra atskirti nuo variklio skyriaus, kad trauktu kuo maziau karshto oro.
ir kamgi tai daryti, jeigu turboj tas oras ikaista iki negaliu. Cia tie keli laipsniai ten ar ten nieko nekeicia...
visgi yra IC to ir uztenka. cia tau ne atmosferikas 8)
NISMO' wrote:ir kamgi tai daryti, jeigu turboj tas oras ikaista iki negaliu. Cia tie keli laipsniai ten ar ten nieko nekeicia...
Klysti. Ir skleidi netiesa.
cia taspats kaip bling bling carui uzdet stockinius ratus.. Nera nei tolko tai daryt nei esmes, turbinoj oras ikaista iki tiek kad rankos nenulaikysi ant to vamzdzio kur ispuciamas slegis. temperaturu skirtumas atitvertoj patalpoj ir atviroj = 10/15laipsniu. Iejes i turba oras taip staigiai ikaista kad ten visi tie atitverimai yra tik lyshnas laiko gaisimas. Niekada to nedarysiu ir tikrai manau nera verta i tai kishti pinigus.
Na del dulkiu ir neshvaros sutinku. Taciau apsileides tas - kuris turedamas turbo auto, ar whatever koks tai, neissivalo engine skyriaus ir nepaliko jo shiny.
Dar karta pasisakysiu, turbo tai ne atmosferikas, kad neatitverus filtro arkliukai tik - Kristu zemyn.
Ziurint dar kokia turbo, didele mazai ikaitina ora.
NISMO' wrote:Dar karta pasisakysiu, turbo tai ne atmosferikas, kad neatitverus filtro arkliukai tik - Kristu zemyn.
Pasisakinek plz apie kazka, ka ismanai... jei tokios sritys egzistuoja :lol:
Pas turbini tai maziau jauciasi, del to, kad to oro "atsarga" visad yra, o ne todel, kad tai maziau svarbu ar turi mazesni poveiki. Nors truputi pasidomek tuo, kas vyksta toj turbo sistemoj pries kazka aiskindamas.
Gazass
Post by Gazass »
As vistik sutikciau su spade nuomone.
Kaip argumentas, jei nera skirtumo salta/karsta, kodel Audi S4 (AAN variklis) ziema (~-10) Turbo pucia 0.9, vasara (~+15) - 1.2 baro :?:
EVO X
Nissan Leaf
BMW E90
extrem
Post by extrem »
Truputi OT :oops: :
:D Kažkas irgi mastė kad nesvarbu ar šiltas ar šaltas oras paduodamas į turbą :D
Renault 11 1.4 turbo
Proton 418 LRS Coupe 1.8 DOHC
Audi A3 1.6
R11 turbo šrotas
RenaultSport.lt
Locked
