Modlist: Ford sierra cosworth 2wd (auto parduotas)
1988 metu
Engine:
200 Cosworth block ( 4WD )
Garrett GT28RS new
FORGE -31 wastegate actuator
RS 500 Intercooler core 600x400x50mm, in/out 3
Silicone hoses 3"
Custom 3" straight free flow stainless steel exhaust
Exhaust mounts - poly-x
Green filter dn 80
BOSCH light blue 400 injectors (437cc/min@3bar)
3 bar WEBER map sensor
18 psi , 310 HP ir 390 NM
Suspension:
Front: Motorcraft shock absorbers
Coilover suspension kit
7" x 450 lbs
Polurethane suspension bushes
Scorpio control arms
Scorpio steering rack
Rear: Koni sport shock absorbers
7" x 325 lbs
Body:
Front strut bar
Rear strut bar
Brakes:
Standart
Front 283 mm x 4 pot
Rear 273 mm
Hydraulic wilwood handbrake kit
Other:
Standard borg warner t5 with quickshift
Air/fuel ratio meter
Oil pressure gauge
Oil temperature gauge
Boost gauge
Sabelt racing seat
Schroth 3 point harness
1988 metu
Engine:
Garrett GT28RS new
Silicone hoses 3"
Green filter dn 80
Suspension:
7" x 450 lbs
7" x 325 lbs
Body:
Front strut bar
Rear strut bar
Brakes:
Standart
Rear 273 mm
Other:
Oil pressure gauge
Boost gauge
Sabelt racing seat
- dsc000201.jpg (180.06 KiB) Viewed 17805 times
Ford sierra cosworth 2WD 2.0 16V turbo
GT28rs, IC 500, Polybushes , coilover
Re: Modlist: Ford sierra cosworth 2wd
kelios foto is projektu
- dsc00009maza.jpg (123.49 KiB) Viewed 17738 times
- dsc00012.jpg (93.13 KiB) Viewed 17669 times
- DSC00030.JPG (191.12 KiB) Viewed 17665 times
2
- dsc00014mod.jpg (193.41 KiB) Viewed 17613 times
- CIMG0516.JPG (163.57 KiB) Viewed 17496 times
rekomenduociau oro filtra atskirti nuo variklio skyriaus, kad trauktu kuo maziau karshto oro.
bus atskirta , projektas dar nera pabaigtas iki galo
su laiku isitikinsi, kad "projekto" neimanoma pabaigt, ji imanoma tik nutraukt.
tas teisybecf wrote:su laiku isitikinsi, kad "projekto" neimanoma pabaigt, ji imanoma tik nutraukt.
Keiciam Bosch light blue 400 ( 437 cc/min / 3 bar ) i Bosch grey 403 ( 503 cc/min / 3 bar )
vnz rezultatas prie 1.3 bar , 310 Hp ir 390 Nm
under the bonnet
- p1000172.jpg (141.7 KiB) Viewed 16365 times
saunucosworth wrote:vnz rezultatas prie 1.3 bar , 310 Hp ir 390 Nm
rs13
Cia is straipsnio vieno , kiek teisybes nezinau :
Approximate standart component power potential:
Crank: - 600bhp+
Pistons: - 500bhp + ( idealy will need maching for lower compression : or use race fuel )
Rods: - 600bhp+
Block: 2wd - 400bhp+, RS500 / 4WD -800bhp+
Exhaust manifold: 2WD - 600bhp+, 4WD- 400bhp
Inlet manifold: 2WD-400bhp, 4WD-450bhp, small turbo Escort cosworth 500bhp+, RS500-700bhp
Intake pipework: 600bhp+
Airbox: 400bhp, RS500-550bhp
Fuel pump: Sierra 400 bhp, escort 350bhp
Unmodified cylinder head: 450bhp
Crank: - 600bhp+
Rods: - 600bhp+
how come kad nera mafo? cia sitas punktas kazka turi bendro 3 bar WEBER map sensor?
nelabai supratau klausimo
standarte MAP'as nu....driver wrote:how come kad nera mafo? cia sitas punktas kazka turi bendro 3 bar WEBER map sensor?
thanks Minde_Kei
standartas 2bar buna , pas mane buvo 2.5 bar , bet suzinojau tik tada kai pasiemiau 3 bar
tokia sakyciau pikta sierra
nei MAF'o, nei lambda zondo nera....
tik keli dacikai ir MAP sensorius.
live the dream
ir kamgi tai daryti, jeigu turboj tas oras ikaista iki negaliu. Cia tie keli laipsniai ten ar ten nieko nekeicia...cf wrote:rekomenduociau oro filtra atskirti nuo variklio skyriaus, kad trauktu kuo maziau karshto oro.
visgi yra IC to ir uztenka. cia tau ne atmosferikas
Klysti. Ir skleidi netiesa.NISMO' wrote:ir kamgi tai daryti, jeigu turboj tas oras ikaista iki negaliu. Cia tie keli laipsniai ten ar ten nieko nekeicia...
cia taspats kaip bling bling carui uzdet stockinius ratus.. Nera nei tolko tai daryt nei esmes, turbinoj oras ikaista iki tiek kad rankos nenulaikysi ant to vamzdzio kur ispuciamas slegis. temperaturu skirtumas atitvertoj patalpoj ir atviroj = 10/15laipsniu. Iejes i turba oras taip staigiai ikaista kad ten visi tie atitverimai yra tik lyshnas laiko gaisimas. Niekada to nedarysiu ir tikrai manau nera verta i tai kishti pinigus.spade wrote:Klysti. Ir skleidi netiesa.NISMO' wrote:ir kamgi tai daryti, jeigu turboj tas oras ikaista iki negaliu. Cia tie keli laipsniai ten ar ten nieko nekeicia...
Na del dulkiu ir neshvaros sutinku. Taciau apsileides tas - kuris turedamas turbo auto, ar whatever koks tai, neissivalo engine skyriaus ir nepaliko jo shiny.
Dar karta pasisakysiu, turbo tai ne atmosferikas, kad neatitverus filtro arkliukai tik - Kristu zemyn.
Ziurint dar kokia turbo, didele mazai ikaitina ora.
Pasisakinek plz apie kazka, ka ismanai... jei tokios sritys egzistuojaNISMO' wrote:Dar karta pasisakysiu, turbo tai ne atmosferikas, kad neatitverus filtro arkliukai tik - Kristu zemyn.
Pas turbini tai maziau jauciasi, del to, kad to oro "atsarga" visad yra, o ne todel, kad tai maziau svarbu ar turi mazesni poveiki. Nors truputi pasidomek tuo, kas vyksta toj turbo sistemoj pries kazka aiskindamas.
As vistik sutikciau su spade nuomone.
Kaip argumentas, jei nera skirtumo salta/karsta, kodel Audi S4 (AAN variklis) ziema (~-10) Turbo pucia 0.9, vasara (~+15) - 1.2 baro
EVO X
Nissan Leaf
BMW E90
Nissan Leaf
BMW E90
Truputi OT
Kažkas irgi mastė kad nesvarbu ar šiltas ar šaltas oras paduodamas į turbą
