Modlist: SUBARU Impreza WRX STi "ZLODEY daily-drive edition"
2005 EUDM SUBARU Impreza WRX STi
* APEX'i intake filter (in stock box) > K&N
* Air intake silencer remove
* Walbro 255 fuel pump
* Megan Racing modified V-band 3" downpipe
* GReddy EVO2 modified V-band catback
* K4RT30Y exhaust hangers
* Prodrive rear diff protection
* Whiteline transmission poly mounts
* CUSCO adjustable front camber plates
* BC adjustable rear camber plates
* KW Variant 3 coilovers with upgraded linear rear springs
* Whiteline F+R sway bars
* Whiteline F+R end-links + bushings
* Whiteline anti-lift kit
* Whiteline steering rack bushings
* CUSCO titanium front strut bar
* CUSCO carbon-fiber rear strut bar
* CUSCO lower chassis bar
* K4RT30Y short shifter + mounts
* JDM STi HID headlights
* WRX fog lights + STi covers
* WRX hood scoop
* USDM hood protector (removable)
* JDM window side visors
* WRX side door moldings
* 2007 STi rear diffuser
* CUSCO JGTC front lip spoiler (removed) > WRX bumper (for winter)
* JDM STi spec-C gauge cluster
* JDM STi spec-C 12L I/C water spray tank + AUTO switch
> Defi Control Unit-II
> Defi BF boost gauge
> Defi BF oil pressure gauge
> Defi BF fuel pressure gauge
> Defi BF EGT gauge
* CUSCO Brake Cylinder Stopper
* Goodridge SS Brake Lines + MOTUL DOT5.1
* DBA 5000 Series two-piece slotted front rotors
* DBA 4000 Series slotted rear rotors
* Ferodo DS2500 F+R brake pads
* ENKEI EVO8 rims R17x8 +38ET + Bridgestone Potenza RE070 235/45R17
* JDM STi spec-C rims R17x8 +53ET + Pirelli SottoZero Winter 210 225/45R17
* ARP #100-7717 wheel studs M12x1.5
* MUTEKI SR48 long wheel lug nuts M12x1.5
* JDM STi oil pan
* K&N Performance Gold HP-1008 oil filter
* MOTUL 5W40 oil 8100 X-cess or 300V POWER
> CUSCO oil catch tank
* APS equal length devided exhaust headers
* APS heat shield kit for exhaust headers
* SAMCO I/C hose kit
* APS air intake kit
* JDM STi spec-C intake manifold
* JDM STi spec-C fuel rails
* JDM STi spec-C 555lph fuel injectors
* Gates Racing timing belt kit
* SS clutch line + MOTUL DOT5.1
* ACT performance-street clutch
? Aeromotive fuel pressure regulator
* Prodrive 3-port boost solenoid
* Prodrive ECU
* SPAL alarm + microwave sensor + automatic F+R windows closing
* COBRA A0158 parking sensors
* JDM STi heated front seats
* Clarion WXZ468RMP 2-Din 6disc MP3/CD player + GSM hands-free
* Clarion SRQ F+R speakers
~ = ieskau
> = turiu
* = sudeta
Re: Modlist: SUBARU Impreza WRX STi "ZLODEY edition"
Gal dar ir gamintojo garantija galioja? :D
JTS
Post by JTS »
oho :shock: tokia bomba netruputi ;)
ViR2ality
Post by ViR2ality »
del garantijos tai vargu :D
neblogas listas, kiek ant dyno prisuka?
Supra MKIII coming soon :)
Conan wrote:Gal dar ir gamintojo garantija galioja? :D
Na siaip tai jo, iki 2008.05.03 dar garantine ir pravaziaviau <45000km...
Mitsu
Post by Mitsu »
O garantija kam? kebului? Nes kiek suprantu, per "garantini" laikotarpi i varikli ir kitus komponentus "rimciau kisti nagus" draudziama? :roll:
EVO VIII GSR SSL (sold)
EVO X MR
fivefivefive
Post by fivefivefive »
Mitsu wrote:O garantija kam? kebului? Nes kiek suprantu, per "garantini" laikotarpi i varikli ir kitus komponentus "rimciau kisti nagus" draudziama? :roll:
Draudziama, kist nagus kist ir i kitus agregatus rankas.
O garantinis itariu jau pasibaiges arba jau eina i gala, nes greiciausiai buvo 3m, masina 05, o dabar 08
O kas del subariko, tai Labai teisingas evo killeris
Renault Megane2 dCi
Black ED7
SIG-Sauer
Post by SIG-Sauer »
:D modlistas nereikalingas EVO kilinti..
Tomas26
Post by Tomas26 »
geras modlist'as zlodey. Greiciau dekis viska, o tai uzsikaupe ziuriu pas tave daliu nemazai :)
wrx
Turiu nuotrauku, paskui padesiu, bet siaip, darant pakankamai paprastus darbus, gavau TOKI h@moroju kad dabar jau net nezinau ka ir daryti... :shock:
Kas mane gerai pazysta, zino apie mano pedantiskuma, kaip as viska darau pagal instrukcijas, kaip viska su dyno raktu ir Nm uzsukineju ir pan....... tai pasakykit man KAS galejo atsitikti kad vienoj pusej brembo suporto du (is karto ir apatinis ir virsutinis) tvirtinimo varztu taskus prasukau pilnai net nedaejus iki uzsukimo ribos pagal instrukcija (155Nm)? "Struzka" tik isemiau............ va cia tai aina nx :?
:( Taip graziai viska isardziau, pakeiciau smeiges i naujas ilgas/sportines ARP, sudejau naujus two-piece dba stabdziu diskus, naujas DS2500 kaladeles....... ir stai tau - ir apatinis ir virsutinis suporto sriegis "isejo". Paskui net specialiai is principo, paziurejus 1000 kartu i instukcija ir nieko naujo nerades, kitoj pusej vel su 155Nm uzsukinejau ir viskas ciki, jokiu problemu!
:?: Zmones, gelbekit... galva visa diena skauda, o cia dar toks "siurprizas" :cry:
a) Daryti didesni sriegi? Supote, stebulej ir dar treciam "pagaliuke"? Gal jau per mazai mesos liks su tokia skyle suporte?
b) Gal kazkaip isfrezuoja su krutom staklem koki sesiakampi, ipresuoja, o paskui pragrezia nauja toki pat sriegi? Nebus problemu su tokia gilze tel temperaturu ar xz dar del ko?
c) Pirkti nauja suporta? Kur?
P.S: Neprates varyti ant kitu, bet speju kad cia visgi JMA galejo su savo "patranka" uzsukinejant pagadint ta sriegi, o as ji dabaigiau, neatlaike jis net ir maziau nei 155Nm.
P.P.S: Garantija baigesi pries 2 savaites... :|
front rotor
front rotor
2piece dba5000.jpg (120.66 KiB) Viewed 24049 times
del ko visas vargas...
dba 5000.jpg (124.01 KiB) Viewed 24539 times
ZLODEY wrote:Turiu nuotrauku, paskui padesiu, bet siaip, darant pakankamai paprastus darbus, gavau TOKI h@moroju kad dabar jau net nezinau ka ir daryti... :shock:
Vaje, o ash galvojau, tik man taip gerai sekasi... Oj kaip pazhystama tokia situacija (viena ish priezhaschiu kodel nepavyko i saskrydi atvykt). Uzhuojautos.
ZLODEY wrote: Kas mane gerai pazysta, zino apie mano pedantiskuma, kaip as viska darau pagal instrukcijas, kaip viska su dyno raktu ir Nm uzsukineju ir pan....... tai pasakykit man KAS galejo atsitikti kad vienoj pusej brembo suporto du (is karto ir apatinis ir virsutinis) tvirtinimo varztu taskus prasukau pilnai net nedaejus iki uzsukimo ribos pagal instrukcija (155Nm)? "Struzka" tik isemiau............ va cia tai aina nx :?
Chm, 155Nm i aliumini - chia gal specialiai japonchegai taip sugalvojo, kad liaudis gadintu tuos sriegius. Bet aishq nerashys manuale, uzhkaitinkit suportus iki 100 laipsniu ir prisukit 85Nm. Ish kitos puses tie suportai paskaichiuoti nuiminet retai, ir tautinem zhiemom nevazhinet. Nenusimink, esu ta pati mates ant bmw suportu, kai vien jau atsukinejant "spyruokle" ant varzhto ishlenda... Bet ten matyt kalta korozija ir sheip "susivirinimas", nes ish kito varzhto kruva miltu ishbiro baltu.
ZLODEY wrote: a) Daryti didesni sriegi? Supote, stebulej ir dar treciam "pagaliuke"? Gal jau per mazai mesos liks su tokia skyle suporte?
Mesos gal ir uzhteks, bet po to kai visur padarysi dideli diametra - jei paaishkes, kad visgi mesos neuzhtenka - kito suporto jau kaip zhinia neuzhdesi. IMHO tupikas.
ZLODEY wrote: b) Gal kazkaip isfrezuoja su krutom staklem koki sesiakampi, ipresuoja, o paskui pragrezia nauja toki pat sriegi? Nebus problemu su tokia gilze tel temperaturu ar xz dar del ko?
Gilze imanoma nebent isriegus isukt. Plienine. Panashei kaip zhvakei helicoilas. Taip daroma, kai daromi suportu laikikliai ish diuralio. T.y. pats laikiklis padaromas ish diuraliaus, o sriegiai yra padaromi ant plieniniu 'insertu'. Klausimas, ar pas tave uzhteks mesos suporte. Man atrodo, kad nebaisiai.
ZLODEY wrote: c) Pirkti nauja suporta? Kur?
Ebay, scrap'ai. Buna avarijoje sugadina viena suporta, tai stumdo nebrangiai antra. Nuo lancerio netinka? Persidazhytum. Beje jei deveta uzhsukinesi su tais 155Nm, lieka siurprizo rizika. Kadangi stabdzhiai dideli ir ash su jais nesusidures - kiek uzsukinet pasiulyt, nezhinau. Pats panashius varzhtus suku ~100, ir karshtus patikrinu.
d) Verzhle niekaip ten netilptu? Blogiausia, kad abu prasukai sriegius. Jei viena, tai galima butu burti kazka (vienas varzhtas normaliai laiko suporta, jei antras varzhtas nekliba).
ZLODEY wrote: P.S: Neprates varyti ant kitu, bet speju kad cia visgi JMA galejo su savo "patranka" uzsukinejant pagadint ta sriegi, o as ji dabaigiau, neatlaike jis net ir maziau nei 155Nm.
Laisvai. O kokio atsiprashant organo jie ten ishvis lindo su ta patranka? Gi ten matyt kas 100k km diskus nebent keist reik...
Didink skyle, suk ivore ant kliju ir prisukinek i ja. Jokio cia kriminalo. Esu mates big brake kit'a kur wilwood suportai tvirtinami ant isnesimu, o tuose isnesimuose "originaliai" susktos ivores. Ir laiko kuo puikiausiai. Tik neverzk taip smarkiai. Manau 100 Nm per akis (o realiai tai turbut ir 70 Nm pakaktu, tik ant sirdies neramu butu :)).
edit: z32 eina aliuminiai suportai, manuale siuloma verzti 98 - 118 Nm.
http://www.300zx-twinturbo.com/cgi-bin/ ... t&total=56
kwlw wrote:
Zlodey wrote:speju kad cia visgi JMA galejo su savo "patranka" uzsukinejant pagadint ta sriegi, o as ji dabaigiau, neatlaike jis net ir maziau nei 155Nm.
Kazkada seniai teko "begti" nuo susidurimo tai uzvaziavau ant borto - pakeite VISA pakaba toj pusej "na vsiakij sluchaj" ...
http://ken-gilbert.com/wrx/STi_Manual/0 ... iption.pdf > 17 INCH TYPE :?
Aciu uz nuomones.... O kas pasiulys rimtus meistrus kurie kokybiskai padarytu toki gilzavima? :roll:
tonic wrote:Didink skyle, suk ivore ant kliju ir prisukinek i ja. Jokio cia kriminalo
Tai kriminalo su ivorem ir nera. Mano abejone, yra del mesos kiekio. Kaip matau (pagal lancerio suportus), ten kokie 8-10mm i shona palikta orginaliai. Ivore visviena savo stori tures kokius 2mm, tai gaunasi reikia skyle tarkuot kokiam M16x1.5 sriegui. Lieka ~6mm aliumo ant briaunos. Ne pyragai, jau su barshkanchiu suportu nepasivezhinsi (bet ZLODEY perfekcionistas - priverzht ir patikrint nepamirsh - matyt shita problema atkrenta). Zhodzhiu glaz almaz metodu, sakychiau dar nera jokio pavojaus, bet ant ribos, del to ta vieta kuri suksis prie stoikes reiktu tiksliai suleist su suporto metalu - nushlifuot ant stakliu (nuimt 0.1-0.2mm, pageidautina nuo ivores), kad ivore ir suportas prisispaustu idealiai prie stoikes. Tada ta riba pasistumtu i ramu miega ir drasu stabdyma IMHO.
Tik va kas tokia stebuklinga plonasiene ivore padarys - tai xzn. O uzh M18 monstrishka kaimo kalvio daryta inserta - ash balsuochiau priesh, o jei truks ar pan aliumas?. STi - tai ne ubage suvartyt, naujo suporto kaina tokiam kontekste = 0.
Black
Post by Black »
ZLODEY wrote:
kwlw wrote:speju kad cia visgi JMA galejo su savo "patranka" uzsukinejant pagadint ta sriegi, o as ji dabaigiau, neatlaike jis net ir maziau nei 155Nm.
Ar tiksliai toki daikta apsims nezinau,bet geras rankas turi "V.Romanovskio Ii" Piliakalnio 17 lygtais,cia pilaitej ,prie Presto tuose garazuose :)
Re: Modlist: SUBARU Impreza WRX STi "ZLODEY daily drive edition"
:arrow: Ka gi, vakar pagaliau surinkau viska atgal. DIDZIULIS ACIU tonic'ui uz patarima ir Eli uz tarpninkavima, skolingas jums alaus (cia rimtai :) ) ...
Prie to pacio padariau dar kai ka - perrinkau priekinius amortikus, pakeiciau smeiges priekyje, uzdejau CUSCO camber plates'us, sudejau armuotas zarneles, pakeiciau stabdziu skysti. Atrodo kad viskas visai neblogai gavosi tik vel su coilu auksciais reiks pazaisti (su KW cia nera taip lengva) :?
camber plates.jpg (38.31 KiB) Viewed 23905 times
ZLODEY wrote::arrow: Ka gi, vakar pagaliau surinkau viska atgal. DIDZIULIS ACIU tonic'ui uz patarima ir Eli uz tarpninkavima, skolingas jums alaus (cia rimtai :) ) ...
Uzh bortelio ideja ant tu ivoriu - lenkiu galva priesh autoriu. Logishkas ir elegantishkas sprendimas. Pagarba.
xennon
Post by xennon »
Grazuma :!: Ir nebuvo taip baisu viskas kaip atrode. Ka ir iskart sakiau :) O borteli daznai specialistai siulo tokio tipo ivorese. Esu ir pats susidures.
Gal po biski ofisas-sandeliukas prades tustet ir viskas atsitos i vietas... :D
Re: Modlist: SUBARU Impreza WRX STi "ZLODEY daily-drive edition"
Ruosiuosi pagaliau isideti Autronic PnP ECU ir panasu kad "sviecia" man nuosavo wideband'o pirkimas. Kaip manot, ar cia butu geras pasirinkimas, ar yra kazkas idomesnio panasioj kainu kategorijoj?
http://www.extremepsi.com/store/custome ... ctid=17967
:?: Kas nors is patirties gali pasakyti ar tas daviklis, kuris daznai siulomas su wideband'u, realiai reikalingas ar gausis kad tai tiesiog "grazus zaislas"? :)
Be jo neveiks tau wide band'as :)
moo
Post by moo »
ZLODEY wrote::?: Kas nors is patirties gali pasakyti ar tas daviklis, kuris daznai siulomas su wideband'u, realiai reikalingas ar gausis kad tai tiesiog "grazus zaislas"? :)
Konkrečiai su šituo komplektuojamas boschinis liambda zondas, koks į daug auto gamykliškai statomas. Viskas ten normaliai su juo.
205mi16
Laimis wrote:Be jo neveiks tau wide band'as :)
:?: Ka reiskia neveiks? Daviklis gi tik rodo skaiciukus :) Man isvis reikia prie ECU tiesiai pajungti...
ZLODEY wrote:Daviklis gi tik rodo skaiciukus :)
Daviklis tik duoda signala, o priimti ji gali tiek ECU, tiek "rodiklis" :)
