Parduodu nauja kuro pompa airomotiv A1000
This is the pump that started it all. Durable, reliable, good looking and it supports high horsepower. Perfect for the daily driver that doesn't run like a daily driver.
Fuel Injected Engines:
up to 1300 HP - naturally aspirated
up to 1000 HP - forced air induction
Carbureted Engines:
up to 1500 HP - naturally aspirated
up to 1200 HP - forced air induction
• ORB-10 inlet and outlet ports.
• For EFI applications use regulator P/N 13101 or P/N 13109.
• For carbureted applications use regulator P/N 13204.
• Fully submersible for custom, in-tank placement.
• Perfect for 'blow-through' carbureted engines up to 1200 HP.
• Billet Speed Pump Controller (P/N 16306) recommended for EFI street applications.
kaina 850lt tel 869982441
Parduodu Kuro pompa
Parduodu Kuro pompa
- 20140604_175556.jpg (68.21 KiB) Viewed 1938 times
Re: Parduodu Kuro pompa
kaina 700lt
