Modlist: Donio S13 sr20det :)
JustDonis
Post by JustDonis »
Sveiki, na manau jau galiu ir as imesti savo kuklu S13'uka :) taigi pradedam... :)
Transporto priemone:
Nissan 200sx S13
Po kapotu:
SR20DET :twisted:
Spalva:
Pilka
Metai:
1991
Kebulo bukle:
Galima sakyt dar padorus :))
Motoro skyrius, transmisija:
@ Cometic Head Gasket 1,9mm
@ New OEM Oil pump
@ Type 1 head (h-dev)
@ CP pistons 86.5mm, 8.5:1 CR
@ Manley H-Beam arms
@ ARP flywheel bolts
@ Supertech Dual Valve Springs 106lb on seat
@ Supertech Titanium Retainers
@ Mazworx Head Stud kit
@ Mazworx Main Stud Kit
@ Apexi manifold Type 2
@ Denso Iridium IK22
@ Kazkoks sandwitch plate
@ Visos tarpines metalines (ismetimo puses)
@ T28bb turbo
@ Armuotos turbos tepimo, ausinimo slangutes
@ Downpipe 76mm
@ Turbo Elbow 76mm
@ ECU Nistune
@ AFM nuo RB25DET NEO 80mm
@ MBC...
@ K&N oro filtras
@ Walbro kuro siurbliukas
@ Virintas diff'as
@ ACT extreme keramika + ACT smagratis
@ B&M short shifter ;]
@ Ismetimas 76mm
@ Apex FMIC su blin bling vamzdynu :D
@ Samco radiator pipes
@ Pasalintas ABS blokas
@ 2x dideli fenai (nuo audi a8 jei neklystu :) )
Pakeisti visi skysciai :)
Pakaba ir pan.:
@ HKS Hipermax 8/6 srping rate coilovers
@ S14 priekines sakes
@ Aftermarket Camber arms
@ Aftermarket Tension rods
@ Aftermarker Teo arms
@ Aftermarket Stabilizatoriai 28mm
@ Issukimo spaceriai 6mm
@ Galiniam tylte aliumo insertai
@ 5lug kit'as is S14a
@ S14a priekiniai suportai + priekyje raizyti diskai
@ Rastavkes: priekis 25mm, galas 30mm
@ Homemade priekines reguliuojamos sakes
@ Homemade vairo traukes su antgaliais
@ Pastumta vairo kolonele i prieki 22mm
Vidus/isore:
@ PROSPORT boost gauge
@ PROSPORT oil temp gauge
@ PROSPORT oil press gauge
@ Momo stebule
@ "Momo" vairas
@ Ratai 4x OEM evo7 R17 8J
@ Skardinukai 2x R16 10,5J
@ Aftermarket sleksciai
@ OEM Kouki galinis spoileris
Na ir keletas foto kaip atrodo dabar :)
tai tiek siam kartui ;)
p.s. prie FMIC vamzdyno nesikabinekit, viska zinau :D :D :D
RS13 ca18 >>> RPS13 :)))
Re: Donio S13 sr20det :)
Bet tai vamzdyno ilgis??? :shock: kodel taip pravesti abu pro kaire puse?
JustDonis
Post by JustDonis »
Taip ir maniau, kad uzklius :D Tiesiog toki gavau ir pigiau buvo taip padaryt nei vest tiesiai ;] laikui begant bus nuvestas tiesiai ;)
klassik
Post by klassik »
Normalus tas vamzdynas.
Cia tam kad nepjaustyt skyliu kebule ir palikti akuma vietoj.
Jau vaziuojantis nissanas? Kas toki motora surinko jei nepaslaptis? :)
JustDonis
Post by JustDonis »
Taip vaziuojantis ;) motoas is UK, pirkau swap'a is Petronio S14a :)
Re: Modlist: Donio S13 sr20det :)
kas tas yr? " Type 1 head (h-dev)"
JustDonis
Post by JustDonis »
damn, tai cia vadinasi tiesiog sutvarkyta galva, i ka ieina naujos gumeles, lizdu raiberiavimas, galvos plokstumos slifavimas ir voztuvu pritrynimas?
JustDonis
Post by JustDonis »
Taip iseina :D as to reikalo nepirkau, tik turiu cekiuka kad buvo tai nupirkta UK :)
tai kam is vis tada rasyt tokias nesamones?ale bile angliskai kazkas?lygiai taip pat kaip ir naujos stabilizatoriu traukes ar oem pompa :lol: :lol: :lol:
Ko jus tokie pikti? :) Tikrai neblogas mod listas ir siaip mielas S13... bus. Kai pabaigs ;)
Pagirtumet ir palaikytumet zmogu vietoj to, kad prie "kableliu" kabinetis.
ne tai viskas tvarkoj neblogas gi tas nissanas bet labai juokingai atrodo tokie modai
Sharas
Post by Sharas »
Nice visai aparatas sakyciau.
Tik kaip tokia apacia tai sakyciau prasosi gan didesnio turbako ir "biski" slegio :twisted:
Volvo RWD - daily
Toyota RWD - race
Nissan RWD - fun
Aha, variklis atrodo zadanciai, dedi turbo vietoj spuogo ir atsuki ag :lol:
JustDonis
Post by JustDonis »
Viskas savo laiku ;) neesu toks kuris turetu milijona pinigu :D viskas pamazu, svarbu tinkama linkme ;)
JustDonis
Post by JustDonis »
Siandien buvo prasuktas dyno run :) su standartiniu ECU ir prie 1bar tokie skaiciukai ~245ag ir 255nm :)
ant lapo raso kad yra 272ag ir 304nm bet kaip man sake vimotoi, tai ten praisuko ratai ir todel tikri arkliai yra pries tai mineti skaiciai ;) o prasisuko todel, kad padangos plikokos buvo :D :D :D
braskiuz
Post by braskiuz »
Truputi apie kreive pora minciu isreikst noriu, kadangi VGTU daznai apsilankau ant dino stendo, dariau kelis labaratorinius darbus tenai ir seip masinas prasuku, tai keli pastebejimai kaip is truputi raukianco zmogaus kaip veikia tai. Jei ratai butu prasisuke tai galia kaip tik butu nukritus, butu tokia dube kreiveje, o ne soktelejus aukstyn. Antras dalykas, net 120 AG prarandama per transmisija? Cia nelogiska kazkas tai blogai.... FWD iki 25% RWD iki 35% AWD iki 40% gali prarast galios iki ratu is alkuninio veleno, bet ne visus 50% jei kaip tu sakai pas tave tik 245. Is visu turimu arkliu puse ju issisvaisto greiciu deze-kardanas-reduktorius. Laaabai jau dideli nuostoliai. Arba vimotos stendas pievas parode..... :?:
p.s. aisku turbut puse dalyviu cia mane isjuoks db... Posta prasiau is praktikos kuria turejau, jei kas turi kitu minciu manau paciam temos autoriui butu idomu isgrist.
p.p.s Grazus 13-liktukas su gero varikliu :!:
Megane III Coupe 2.0 + sraigė
is kur tu ta 120ag nuostoli matai??
Willy
Post by Willy »
is transmisijos nuostoliu kreives "PLoss"
braskiuz wrote:Truputi apie kreive pora minciu isreikst noriu, kadangi VGTU daznai apsilankau ant dino stendo, dariau kelis labaratorinius darbus tenai ir seip masinas prasuku, tai keli pastebejimai kaip is truputi raukianco zmogaus kaip veikia tai.
Na, taip mokymo vardan... isivaizduokim kad cia virtualus seminaras.
Klausimai studentui:
Nuo ko dar (be to ka isvardinai) priklauso nuostoliai?
Ar tamsta tikrai nematote bedos su galios nuostoliu isreiskimu procentine israiska?
Kaip galima paaiskinti ta "guza" ties redline'u?
p.s. Prasymas moderatoriams: palikit kol kas sita diskusija sioje temoje - paskui isskirsit, kai issisems. Dekui.
LiNeLiZz
Post by LiNeLiZz »
Tai as nesuprantu, kas per power loss skaiciai kai matuojama galia i ratus ir kaip gali pasakyk kiek galios prarandi per deze, kai to net nematuoji?? Beto, skaiciai pas Tave kazkokie "through the roof" todel kad kuo daugiau arkliu tuo mazesnis power loss ir seip cia pagal mane turetu gautis kad per transmisija ir padangas prarandama apie 15,12% galios nuo 320,45bhp @ flywheel... (272 + 10 : 0.88 = 320.45; 320.45 = 100%, 272 - x%, tai paskaiciavus gaunasi, kad 272 yra 84.88%, t.y. 15,12% skirtumas tarp power @ flywheel ir power @ wheels). Aisku as galiu but neteisus, bet man kazkodel atrodo, kad Tu labiau klysti, PEACE :wink:
Ir seip jeigu nori suzinot tikrus perdavimo nuostolius, tai reikia pamatuot galia @ flywheel su tiksliu variklio dyno, o galia i ratus ant tikslaus vaziuokles dyno ir atimti viena is kito... Sitoj zalioj zemej nera jokio budo pamatuoti TIKRUS perdavimo nuostolius matuojant tik galia i ratus...
P.S. Atsiprasau del tos ENG/LT kalbos, zinau, kad daug kam nepatinka, bet kitaip issireikst nemoku..
BD Motorsports
braskiuz
Post by braskiuz »
Gali but brangus forumieciai nesigincisiu. Bet teorija tokia su visais LT dyno stendais yra tokia, kad (is kit klubo suformulavo gan tiksliai)
T.y. ismatuoja Nm ant ratu akseleruojant maksimalia pavara nuo artimu sukiu laisvoms iki pat ribotuvo (t.y. iki max greicio) ir tada numynus sankaba duodama ratams sava eiga sustoti ir sitoj vietoj yra skaiciuojami transmisijos nuostoliai. Ir rezultatus ant lapo mes matom, deja, jau paskaiciuotus i alkune, o ne tuos kuriuos realiai issukom i ratus. Del nuostoliu sakiciu gal ir perlenkiau, bet as bent jau tokius atsimenu ir kiek intike skaitinejau. :roll:
tomas.ep3
Post by tomas.ep3 »
zmogus juk pasake kad sukosi su plikom padangom, uzvirintu dif'u, todel nenustebciau kad ten kai turejo skaiciuotis nuostoliai gale gavosi gavno :wink:
Seat Leon Cupra Tdi...
LiNeLiZz wrote:P.S. Atsiprasau del tos ENG/LT kalbos, zinau, kad daug kam nepatinka, bet kitaip issireikst nemoku..
Mokintis reik. Ir net ne tiek kalbos, o aiskiai mintis reikst. Nes dabar nesigauna sekti, kai toks kratinys.
Ir siaip... mazumele atrodo, kad tamsta nelabai sugebate "skaityti" dyno kreives... tai gal nereiktu pulti kitus mokyt?
Is kur tie keisti skaiciai 15,12 ir 320,45?...
fregis
Post by fregis »
dar jie ta diena tingejo ventiliatoriu pries IC statyti :roll: tipo sake neuzkaista ... vienam su 1.3 lyg bar ic virs 60 laipsniu uzkaito (ir tai matuota kai nuvaziuota buvo nuo stendo), tai vien jo kiek nuostoliai...
