Nissan 200SX S13 FAQ (DUK)
Tech. duomenys:
http://www.per4m.lt/forum/viewtopic.php?t=1004
Remonto knyga (manualas):
http://www.per4m.lt/manuals/s13.rar
ECU testas:
http://www.per4m.lt/forum/viewtopic.php?t=2211
Tobulinimo planas:
http://www.per4m.lt/forum/viewtopic.php?t=268
How to: SR20DET swap'as
http://www.per4m.lt/docs/sr20det_swapas.pdf
Puslapiai apie S13
http://www.per4m.lt/forum/viewtopic.php?t=3288
Patarimai perkantiems:
http://www.per4m.lt/forum/viewtopic.php?t=925
Kuro sanaudos:
http://www.per4m.lt/forum/viewtopic.php?t=171
ECU testas:
Tobulinimo planas:
Puslapiai apie S13
Kuro sanaudos:
Re: Nissan 200SX S13 FAQ (DUK)
How-to: S13 JDM Digital Climate Control ( Klima )
http://www.zilvia.net/f/tech-talk/15442 ... ntrol.html
http://www.eatsleepboost.lt/files/manua ... manual.pdf
vairo kryzmes saga DIY
stock sagos aukstis ~10mm
veikianti nuoroda į S13 manual'ą.
http://www.silviansw.com/manuals/s13_manual.zip
A2 ekonom
Audi TT quattro mk1
Audi TT quattro mk1
Lambada sensor M18 x 1.5
Oilfilter 3/4" x 16g BSP
Head to exhaust manifold studs M10 x 1.25
Turbo elbow studs (3 of them) M10 x 1.25, note that the part of the stud that is screwed in the cast elbow is a regular M10 x 1.5
Turbo water feed banjo bolt(turbo side and engine side) M14 x 1.5
Wheelstuds M12 x 1.25
Oilpressure sender 1/8 x 28g BSPT
Dashboard watertemperature sensor (with one wire)M12 x 1.25
ECU watertemperature sensor (the one with two wires) M12 x 1.5
Turbo oilfeed
Thanks to Ben at Hosesolutions for these precise details:
turbo side: 7/16JIC X 24tpi
engine side (elbow): S13 is M12 x 1
engine side (banjo): S14 is M12 x 1.25
engine side (banjo): S15 is M12 x 1.25
S13 Turbo oilfeed elbow
Thread in engineblock 1/8 x 28g BSPT
Thread in elbow M12 x 1mm
Copyrait @ SXOC.COM http://www.sxoc.com/vbb/showthread.php?t=64002
perpostinu chia manau verta, kad nepradingtu.
Turbo oilfeed
Nesenai man paciam reikejo (manual'as to neduoda). Sr20 bellhousing'o varztai:
2 12mm x 1.75, 75mm each
1 10mm x 1.50, 90mm each
1 10mm x 1.50, 35mm each
4 10mm x 1.50, 65mm each
4 12mm x 1.75, 75mm each
project チームbeat
Kaip tai neduoda?mindish wrote:Nesenai man paciam reikejo (manual'as to neduoda). Sr20 bellhousing'o varztai:
ir sriegio zingsnis lyg 1.5 mm visur
jau senai nebuvo tonic'o sr20det swapo manualo "validaus šaltinio", tai padariau:
http://eatsleepboost.lt/files/manuals/t ... swapas.pdf
