modlist: McPie RX-7 - ENGINE BLOWN - for sale
McPie
Re: modlist: McPie RX-7
Post by McPie »
butu plienine sake, tai deginciau
kadangi aliumas, tai kazkaip gal geriau nereikia degint...
RX-7 13B TII restauruojamas
929 + RX-7 = RX-4 powered 13B 6port NA with ITB
McPie
Post by McPie »
slepiuosi po kazkuriais tai lapais nes 1.2 BAR nebera maza to
pute 0.7 kotais nebeuzpucia tu 0.7 tepucia NETGI 0.2 BAR
todel kaip su 0.2 BAR esu VERY HAPPY 180HP i smagrati kaip atmosferikas praktiskai :lol:
180HP@6500RPM
210Nm@5500RPM
su salyga kad putimo problemos bus isprestos - KADA NORS :D
tuomet dar karta prasuksiu ir tikiuos bus geresniu rezultatu :)
xennon
Post by xennon »
Cia kur sukai, kad i ratus parode?
McPie
Post by McPie »
pataisa i SMAGRATI
sukta gariunuose...
McPie
Post by McPie »
kazkaip taip jau isejo, kad map'inti as nemoku o masinele vaziuoja vistiek netaip kaip as noreciau
tarpines on da way to FC, bet stai naujas procas i FC kompa tai manau tai ko truko iki teisingo jos veikimo :D
Mazda RX7 Turbo FC3S 1989 - 1991
Boost cut - Removed
Fuel cut - Removed
Rev limiter - Removed
Fuel and timing maps - adjusted to provide a much more snappy and responsive drivers car, the torque curve rises much more sharply.
Mapped up to 15 PSI !!! ~1bar
You will need a free flow air filter. +
A good free flowing exhaust. +
And of course the higher the octane rating petrol you use, the more performance. +
ir iki pilnos laimes liko susidet naujsu stabdzius....
McPie
Post by McPie »
lyg it geriau nei stock
McPie
Post by McPie »
nuvezus auto i UK SILVERSTONE AUTOSPORT servisa, kur vyrukai dirba su eriksais ir subaru
buvo atlikta keletas darbu:
a) pakeista turba, nes pasirodo suluzo WG
b) pakeistos tarpines, nes buvo prapustos
c) permapintas ECU, perprogramuotas greddy - be komentaru..
d) pakeisti darvikliai, pasalinti bugai sutvarkytas laidynas
Rezultate masina isgavo 257AG ir 332Nm
dyno sheet shortly
McPie
Post by McPie »
nepatinka man ta duobe, bet yr kap yr...
jinai jauchiasi vaziojant ? nes gal ratai prasisuko ant stendo arba mapintojas kreivas
McPie
Post by McPie »
vakar pasemiau masina i serviso
tai uk keliai vietomis slapi vietomis pasnigti kaip ir nebuvo progos normaliai spustelt
5tu begiu vaziuojant 120m/h buvau atvyniojes iki 5500RPM, bet is kart atleidziu gaza, nes nera kur begetis, negaliu pasakyt ar jaucias..
beto padangos vasarines tikrai neperdaugiausia gripo gali buti, kad praslydo...
visi arkliai yra prie stock 0.7bar boost'o ir throttle respond yra geiras, bei turba pradeda pusti nuo 1700RPM
ir smagu ir baisu vaziuot ziedais, nes vaziavimas tarp grip ir "drift" tobish slystelta bet tuo paciu ir gripa prilaiko, sliapia danga daro savo...
tiesa turba gali pusti 1.2 bar tai su tiek gero perliptu 300ag bei 400Nm ribas
McPie
Post by McPie »
Del netiketu posukiu gyvenime(tapsiu teveliu), auto paruodamas....
1991 MAZDA RX-7 FC TURBO II S5
Saziningai be isvedziojimu....
masina stovvi, taciau kartai uzkuriama pavaziuojama ir vel pastatoma. TA ar draudimo nera
reikia:
* sutvarkyti kebula nuo keletos skyluciu, foto artimiausiu metu, perdazyti. (parduodamas su R17 driz ratais, dangteliai visi yra)
* kapotas aliumas nuo kabrioleto.(REIK SUSIREGULIUOTI)
* DIF'as leakina, reik pakeist riebokslius
* ismetimas yra custom, galiu uz simbolinius 500LT perleist stock + 3' downpype ir dali vamdzio.
* galine viena lepa lengvai skilus turiu geras looks like brand new (500lt)
* Coilai bus isimti ir sudeti stock amortikai su zemintom sprunzinom. Like poliuretaniniai sailenblokai lieka, nekeisiu.
* priekines lempos nedega...(?) kazkur uzsibugino elektra
* pradejo lengvai leakinti vairo stirprintuvo hidraudrilinio skyscio ausinimo vamzdukas.
* kas 20min isijungia FUEL CUT'as neleidzia boostinti. laikinas spredimas isjungt/ijungt degimas. Konsultacijos
su silverstone autosport teigia, gal purkstukai(varza ne ta). Siurblys ok, MAF keitimas rezultato nedave. Zvakes keistos
taip keisti ir zvaklaidziai.
visa kita galima sakyti ledas. Noriu nedaug visa komplektacija 15000Lt
Galimas variantas parduoti kebula atskirai
861806725 t.pyragas@gmail.com
Widzia
Re: modlist: McPie RX-7 - PARDUODAMAS
Post by Widzia »
Va cia tai netiketas posukis :D
TaT
Post by TaT »
pranesk jei ardysi ir trauksi swapa. :)
McPie
Post by McPie »
jei ir ardysiu tai tik isimsiu varikli su visais laidais/davikliais ir "sport pakaba", visa kita paliksiu pilnoj komplektacijoj... kaina tokio komplektuko butu 3.5k lt
pirkejui neatsiradus, automobilis bus pilnai demontuotas pervirintas perdazytas ir surinktas su refurbishintu 13b tii varikliu.
Sudeta stock pakaba, stock reduktorium, refurbishintais originaliais r15 BBS diskais ir parduodamas uz 30000k Lt arba liks asmeninej kolekcijoj... :)
McPie
Re: modlist: McPie RX-7 - gaivinamas
Post by McPie »
Erika is Back as White Shadow
buna pamatau jus ten prie garazo kartais :) geru masinu ten privaziuoja :mrgreen:
ratu ratu reik geru
McPie
Post by McPie »
SLEEPER mode ON
nuo 1 iki 1.5BAR boost. Perdaryta stock turbo i HIBRIDINE
naujas turbo vamzdynas ir zarnynas
naujos vakuumines slangos
nauji priekiniai zibintai
beliko prisiregistruoti is naujo ir TA :)
kas ten apie ratus? Stock wheelz is the best
dropo nebus, ir taip zemai dugnu asfalta braukia... nebent deti stock isvaizdos R16 ar R17
slimas1
Post by slimas1 »
Ant stendo prasukai? :)
Mazda 3 BL 2.3T MPS
McPie
Post by McPie »
NX stendas - uztenka, kad ir kiek bebutu :)
kam idomu, galima kokiam vingiuotam kely ir pasimatuoti kates peles zaidimo principu...
dexter
Post by dexter »
Trūksta tik RedSuns lipdukų ant šonų :D
McPie
Post by McPie »
padėkit kas galit prašau reikia greddy e-manage blue duomenų perdavimo kabelio USB A-USB A
bandžiau pasigaminti per adaptorių - kompas neatpažįsta.
be jo negaliu sureguliuoti papildomų purkštukų :evil:
McPie wrote:Sveiki,
dareisi pagal DIY is neto?as kazkada dariausi viska pagal jy,irgi nepavyko,galutiniam rezultate pirkau is UK,bet jau pardaviau as jy su visu kompu,dabar nerandu linko,kainavo 15 svaru
McPie
Post by McPie »
too bad engine blown - GAME OVER
roling shell with all bits for sale 3000 EUR
McPie
Re: modlist: McPie RX-7 - ENGINE BLOWN - for sale
Post by McPie »
Eina nx tas ziaurus likimas mane suvede ir niekaip neiiskiria su eriksais bei rotoriais...
Pilna restauracija laukia... ka kogero reikejo senai padaryti..
Kaip sako it is not over till it's over....
