Ernnis project - skyline
Ernnis
Post by Ernnis »
GTR R32
Modlist:
Fully built engine by RB MOTORSPORTS:
RB Motorsports gold engine covers
Trust Iridium 8# spark plugs
Greddy clear cam cover
Tomei Cams and Pulleys 260x9.15
Tomei kevlar timing belt
Tomei metal head gasket 1,2mmx87
Nissan OEM cam and crank seals
RB Motorsports Forged Pistons kit 86,5 and ring set
Block rebore to suit pistons
Nissan N1 Oil pump and gaskets
Tomei con rod set
Tomei con rod bearing set
Nissan OEM main bearing set
Dynamically balanced crank and flywheel
Trust sump baffle kit
HKS GT2530 Turbo kit
HKS uprated actuators
HKS Turbo elbow kit
HKS downpipe
HKS full exhaus kit
Nismo Injectors 800cc 6x
Tomei Fuel presure reguliator FPR
Tomei Fuel pump
Nismo Aif Flow Meters MAF 2x
HKS Racing suction kit
HKS Racing intercooler kit FMIC
HKS Super SQV kit 2x
RB Motorsports Oil cooler
Aliuminium cooling radiator
Silicone breather hose kit
Water hoses set
Apexi Power FC
TRANSMISSION:
OSG Twin Plate Carbon clutch
Short shift
Nismo rear LSD
SUSPENSION:
Ohlins coilovers
Adjustable tension rods, front anr rear camber arms
Hicas eliminator
R18 x 9,5
Brembo brakes
Ferodo DS2500 pads
OTHER:
Defi oil pres., turbo, ext. temp. gauges
Shift light
Blitz boost controller
Skylab torque split controller
External fuel pump bosch 044
Roll cage (FIA)
Sparco driver seat (FIA)
Sabelt second seat (FIA)
Sabelt belts (FIA)
Bmw E61 530D
Ernestas, 868879757
Re: Ernnis project - skyline
Kam idomi istorija sitos auto - ziurim cia: http://www.per4m.lt/forum/viewtopic.php?f=18&t=7941
Erni - pridek Mod lista - kitaip mes lauk tavo tema (o beto pridet irgi yra KA!)
Blemba faina matyt ja vaziuojancia (ir svarbiausia - NUPLAUTA bl :D)
:twisted: Super!
festest
Post by festest »
koks dar beveik vaziuoja, siandien (o gal vakar) sauletekio ziede jau sukaisi, teko net persisukt. dar mintyse iskart toptelejo "o jau gyvas" :lol:
OAF GSi
125kw 2.5l
OCA SAPNELIS project
...kw 2l
OCB
33kw 1.2l
mk2 darbine duja
60kw 1.6l
OCA pilniausia komplektacija
60kw 1.7D isuzu power
xennon
Post by xennon »
Pagaliau :D
Kad jau TEN nusifotkinai, tai ir laikus imesk idomumo delei :)
Ernnis
Post by Ernnis »
nieks nematavo :(, pasirodo jau akcijos nebevykdo...+ važiavau atsargiai, juk pirmas kartas...
Bmw E61 530D
Ernestas, 868879757
niekotokio
Post by niekotokio »
geras projektas :) o fastlape rugseji pamatysim sita gyvuli?:)
zhy
Post by zhy »
kreivės :shock:
fzs 600
bnv e36 traktor
Todo2
Post by Todo2 »
nu patranka........! :shock:
graziai ziurisi...
rs13
niekotokio
zhy wrote:kreivės :shock:
beje,del kreiviu:nesu mates daug skyline'o kreiviu,bet pagal vaizda labai "atmosferine" kreive.cia visuomet taip pas skyline'us?tarp5-7500 turetu buti linksma :)panasu,kad maziau 5000rpm nelabai verta leisti nukristi apsukoms.ar gatveje kitaip?
Cia TT - del to ir kreive tokia... Ir 2830 nera is didziuju.
niekotokio
tai vat as ir maniau,kadjei turbos nera dideles, apacioje/viduriniame diapazone kreive galetu buti siek tiek plokstesne.kaip suprantu cia hks'o analogai garrettui gt28(tik zinoma x2)?
sitos turbos kiek pamenu iki 700ag - tai jos ir negali kazko stebuklingo tureti apacioje
ZiGa
Post by ZiGa »
o kiek dbr puciama su sraigem? :) o siaip gal purkstuku didesniu neprosal butu :roll:
'92 Black N14 GTi
Jep - cia tas pats garett GT28 tik kad su HKS stampu ir "kazkokiais" pakeitimais...
Mano svajoniu auto,+10,keep up
Ernnis
Post by Ernnis »
kreivės su 1,4 baro. Purkštukų reikia, bet planas: kaltinis motoras ir E85 kuras.
Bmw E61 530D
Ernestas, 868879757
niekotokio
Ernnis wrote:kreivės su 1,4 baro. Purkštukų reikia, bet planas: kaltinis motoras ir E85 kuras.
panasu,kad bus arkliu:)
o dabar viduriai ne kaltiniai?
ZiGa
Post by ZiGa »
o masina time attackui ruosi?
'92 Black N14 GTi
Ernnis
Post by Ernnis »
viduriai nekaltiniai :(, auto ruošiu žiedui ir tiek..., šiaip net nežinau kur su ja važiuosiu. Auto - for fun
Bmw E61 530D
Ernestas, 868879757
niekotokio
o kiek skaitoma,kad turetu atlaikyti standartiniai viduriai?beje,kokia mase dabar?
Ernnis
Post by Ernnis »
niekotokio wrote:o kiek skaitoma,kad turetu atlaikyti standartiniai viduriai?beje,kokia mase dabar?
su standartiniais viduriais iki 600 ag, nes paskui ir dėžė nebelaiko. Masės nežinau, bet tikriausiai didelė :(
Bmw E61 530D
Ernestas, 868879757
niekotokio
bet 600 jau yra nemazai ziede :))) o kokia mase pagal technini pasa?
ZiGa
Post by ZiGa »
per akis ir 600 :D o siaip manau smagiau koki 450 - 500 bet su geru spoolu apacioj, butu toks miestinis fun caras :) ir nereiktu jokios kaltienos ar dezes :roll:
'92 Black N14 GTi
niekotokio
aha,miestinis fun-caras su homologuotais lankais :)be to su sitas turbo-kitas ne spoolui o 600-700 ag.mano galva, nera jokio tikslo tureti dideles turbas ir tureti su jom maziau nei 500ag-nei spoolo nei arkliu.siaip labai idomu butu pamatyti sita automobili "in action" :)
ZiGa
Post by ZiGa »
na as ir turejau omeny ne boosta mazint, o turbas mazesnes det :) o kas del lanku, tai nereiskia kad masina naudot reik grieztai pagal paskirti :wink:
'92 Black N14 GTi
