"(...) The production of the 3rd generation Caldina ended in 2007. That was also the end for both the renowned 3S-GTE engine and the legendary "GT-Four" monicker in Toyota's lineup"
http://en.wikipedia.org/wiki/Caldina
3S-GTE RIP
3S-GTE RIP
vairuoti nemoku, bet uztat labai megstu!
... liudi seima, gimines, draugai ir pazystami. Amen
TOYOTA zhudo pati save
toyota nuzhude visus GTE, iskaitant i jz serija
Supra MKIII coming soon
Re: 3S-GTE RIP
Na neliūdėkim taip labai. Atsirado toks daiktas kaip 2UR-GSE, dedamas į Lexus IS-F
http://en.wikipedia.org/wiki/Toyota_UR_engineThe 2UR-GSE is a 5 liter (4968 cc) engine and will power future Lexus vehicles. It has D-4S gasoline direct injection, dual VVT-i, and VVT-iE on the intake. Bore of 94 mm and stroke of 89.5 mm, it will produce 416 hp (311 kW) at 6,600 rpm and 371 ft·lbf (505 Nm) of torque at 5,200 rpm.
Re: 3S-GTE RIP
a kur T raideleG3D45 wrote:Na neliūdėkim taip labai. Atsirado toks daiktas kaip 2UR-GSE, dedamas į Lexus IS-F
be to, iki 100AG/1L vis dar biski truksta...
Re: 3S-GTE RIP
nieko, uzhtat IS-F yra M3 killeris
GTE varikliu man kazhkodel taip atrodo, kad ateityj nelabai ir bepamatysim, bent toki vaizda susidariau zhiurint i toyotos ir kitu autogamintoju sukama krypti
