Open diffas i lsd
giegus
Open diffas i lsd
Post by giegus »
Gal kas nors domejotes, ar galima kuriu nors Toyotu LSD keisti tarpusavyje. Konkreti situacija: vietoj lexus gs diffo (su visu korpusu) galima ideti diffa is lexus sc arba toyota supra jza80. Tik situose mdeliuose lsd buna pakankamai retai - tik suprose tt, kai kuriuose soareriuose ir aristo. Galbut imanomas panasus variantas kaip nissanuose, kad su mazais perdarymais i s13 diffo deze galima ideti serenos lsd kartu su pusasiais. Galbut imanomas analogiskas variantas su kokiu nors toyota hiace arba hilux :)
Butu labai malonu, jeigu kas nors pasidalintu savo patirtim ar internete uzmatyta informacija
tng
Re: Open diffas i lsd
Post by tng »
cia tu i mark 1 aristo nori ?
check PM
past [ '00 jzs161 Aristo Mk2 ]
present [ '02 e39 530d ///M ]
enjoyer
Post by enjoyer »
Ma70/Jza70 visos turbinines buvo su LSD. Aisku, jei is Ma70 tinka i Aristo.
Toyota MR2 Spyder
Ex. Ford Capri 2.0 S
Ex. Mazda Mx-5 NB 1,8
Ex. MK3 Supra. 7M-GTE
deshriuz
Post by deshriuz »
Radau uzsieni taip kalbant: "Selling my LSD Differntial from a Twin Turbo Toyota Aristo. It has 3.77 gears in it and it is in fantastic shape. I took the rear cover off to verify gearing and condition. This diff is a direct swap into 1993-1998 Twin Turbo Automatic Toyota Supra's and is virtually identical in every way other than some casting on the housing for cooling fins. It also swaps directly 1991-2000 Lexus SC300's and Lexus SC400's, 1993-1998 Non Turbo Toyota Supras as well as 1993 - 2002 Lexus GS300's and GS400's but you have to swith the front flange out with the one currently on your diff. Very Simple to do. To do this swap, expect it to take as little as a half an hour and as long as 2 hours depending on your skill level."
Nuoroda i foruma http://www.clublexus.com/forums/1gen-gs ... ntial.html
AE82GT Twin Cam 16
Kiria
Post by Kiria »
lexus is300 su lsd
Padangų montavimas, balansavimas ir remontas pigiai. +37060222322 Klaipeda
