ITB
2b4u
ITB
Post by 2b4u »
VIDEO:
http://ru.youtube.com/watch?v=oeqIWdTZ9Ww
For sail:
http://www.honda-tech.com/zerothread?id ... d=29741883
http://hondamarketplace.com/zerothread?id=2131764
Suprantoma kad pageres respons`as...Idomu kiek dar naudos galima is ju gauti?
Honda i-VT B20*VTEC - Drag
Nissan Silvia Grand Prix*[FJ20E] - Daily
http://www.DragWars.lt - Nauja Versija!
JTS
Post by JTS »
naudos daug, bet kiek zinau visas torkas su ag persikels labai aukstai, prie zemu gali atsirasti biski nevalas :) bet kai tai H tai nematau dideliu parkiu...
Pasak Puma Race Engine - ganetinai nemazai:
The fuel injection equivalent of the DCOE, these are usually used to replace a standard single or twin butterfly plenum injection system. Expect about 10% increase in power as an average on a standard engine with up to 15% on modified engines as the standard plenum gets more restrictive. It all depends on how good the standard plenum system is of course and how heavily the rest of the engine has been modified and therefore how restrictive the standard system has become. The Vauxhall 2 litre XE engine for example is particularly responsive to having throttle bodies fitted and you can expect to see about 180 bhp instead of the standard 150 bhp (20% extra power) with just these and a decent exhaust system in a Westfield or similar. Of this the TB's are probably adding low 20s bhp and the exhaust the rest. Claims of well over 200 bhp with just throttle bodies on this engine abound though and you can make your own minds up about those. I've just had some engine dyno feedback on a 2 litre Zetec where our 45mm TBs increased the power from 174 bhp to 201 bhp (plus 27 bhp) on a modified engine in a back to back test against the standard plenum. By contrast the plenum system on the Peugeot 1.3 TU Rallye engine is so good that TB's only add another couple of bhp. They do improve torque in the lower part of the rev range though. Copyright David Baker and Puma Race Engines
Saltinis: http://www.pumaracing.co.uk/gentune.htm
fotonas13
Post by fotonas13 »
Buvo gi lt drage kazkada toks civic'as ar foto maciau.
Siaip sutuninti ten pakankamai sunku.
2B4u go for it. Beje nuo kazkuriu moto viskas tinka.
http://homemadeturbo.com/tech_projects/itb/index.html
03 CTR K20a2 Sold
s2000 ap1, ap2 Sold
08 135i manual Sold
2b4u
Post by 2b4u »
ACIu uz info :wink: as jau zinau koks mano sekantis mod`as... :)
fotonas13
Post by fotonas13 »
http://www.team-integra.net/sections/ar ... icleID=484
Siaip paskaiciau, biski tai ten reiklau su TPS yra ar moto tokia pat itmap duoda atidarytas ir uzdarytas.
vakumo visos shlangos is kazkur kitur tuti buti atvestos.
IAVC reikia palikti tik nepajungti.Nu darbo yra bet. :D
Butu idomu ka SOHC, ishgautu is tokio setup.
Gaila for dayly use nlb. :x :cry:
03 CTR K20a2 Sold
s2000 ap1, ap2 Sold
08 135i manual Sold
2b4u
Post by 2b4u »
fotonas13 wrote:http://www.team-integra.net/sections/ar ... icleID=484
For daily use viskas ok tik reikia AIR BOX:
http://www.honda-tech.com/zerothread?id ... d=27714276
lietuvoj drage corsa berods vazhiuoja su ITB, dvilitris jei neklystu.
ard wrote:lietuvoj drage corsa berods vazhiuoja su ITB, dvilitris jei neklystu.
Ir ka?
2b4u
Post by 2b4u »
Pas mumis daug kas su ITB... as bent 5 zinau... dar buvo honda(SKUBA).
