Idomus stabdziai
STRIXas
Idomus stabdziai
Post by STRIXas »
Stai kokius stabdzius uztikau sendien parodoje ant kit caro koks tokius tabdziu tixlas svoris?
Re: Idomus stabdziai
Kiekvienas savaip dvirati ishradineja ;)
Tikslas gal atkreipti demesi parodoje. Koks cia aparatas?
STRIXas wrote:Image
Matyt. Kazka panashaus teko matyt pas dragsterius.
Ir stabdymo plotas nera ispudingas, netgi atsizvelgiant i tai, kad double diskai..matyt nelabai didelis svoris tos transporto priemones
driver wrote:Ir stabdymo plotas nera ispudingas, netgi atsizvelgiant i tai, kad double diskai..matyt nelabai didelis svoris tos transporto priemones
Stabdymo plotas dvigubai didesnis, todel sakychiau nera jis mazas. Viskas priklauso nuo mases, jei chia aparatas su motociklo varikliu ir sveria 250-300kg, tai jam tokiu stabdziu uztenka...
STRIXas
Post by STRIXas »
nu ce kit caras bet variklis hondos s2000 neatkreipiau demesio kokio pavadinimo jis tik uzstrigo stabdziai
kaimietis
Post by kaimietis »
ispanmu "gamintojas" aspid. http://www.aspidcars.com/ kaina 75 k svaru :)
autocar: "The Aspid's unusual braking system has been patended. It features a double discat the front with as much metal as possibel removed from the disk surface, to improve the airflow over the brakes and to cut weight. The double disc design allows for smaller calipers, which also cuts weight. the whole front suspension, hub and brake assembly weights just 7 kg."
anot ju, variklis civico (pats maciau, kad ten f serijos, t.y. s2000) 270 ag arba supercharged 400ag.
MICRA dci 82 ag
S2000
kaimietis wrote: autocar: "The Aspid's unusual braking system has been patended. It features a double discat the front with as much metal as possibel removed from the disk surface, to improve the airflow over the brakes and to cut weight. The double disc design allows for smaller calipers, which also cuts weight. the whole front suspension, hub and brake assembly weights just 7 kg."
Labai jau brangus tas ju mases taupymas. Idomu kiek mm vaikshto tie ju diskai ant hub'u. Nes kai ta kaladele viduryje pasidevi - tarpas tarp disku turi mazheti. Nu nezhinau nezhinau ar chia labai jau gera konstrukcija. Panashiau i klasikini overinzhinieringa, kai 5% gain'as (prie laboratoriniu salygu) marketioru pristatomas kaip 500% ir sheip kaip perversmas visoje shakoje :D.
