Apexi SAFC reikia patarimo
Sveiki. Nusipirkau apexi safc. Aisku jungiu ne ant jdm bet ant euro car'o. Taigi turiu klausimu kas jau buvi susidures. Biski neikertu settings ant apexio pasirinkus hot wire gaunu langeli in ir out su tps signaloo kryptimi. Nelabai suprantu kas tas IN ir OUT. Gamykliskai tuose langeliuose parasyta 1. Bet narsant kituose forumuose randu pvz IN 2 OUT 5 ir panasiai. Kokia reikšmė tu skaiciu. Ačiū.
Re: Apexi SAFC reikia patarimo
If you are sure that the voltage is acceptable for your Super AFC, you can now set the throttle sensor type in the Car Select mode. If the TPS voltage is 0 V to 1 V fully closed in the previous step, set the arrow to the upward direction. When the throttle voltage is 3 V to 5 V, set the arrow to the downward direction.
When the arrow is set to the ** mark, no correction is performed by throttle opening.
Su tps signalo kriptimi kaip ir aisku. Lieka po klaustuku IN/OUT mafo nustatymais.
matau tu manualo beveik neskaitei,kokia pas tave srauto matuokle?taigi surasyta jame variantai,pasirenki koks tavo
Skaiciausi manuala. Bosch matuokle hot wire. Klausiu nes suglumino forumus paskaicius vieni statosi IN/OUT 13 13 kiti ant n62 mafu 2 5 ir panasiai.
