tepalas transmisijai
DeeDee
Post by DeeDee »
as ir agipu nesiskundziu :roll:
Volvo S80 2.5 TDI 1999
r7kyc82k
Post by r7kyc82k »
dar niekas nussikimso del priedu. vat nuo pigaus tepalo tai kemsas, ir nuo variklio praploveju :-))))))
komikai.
SV650 , Daytona 955i
http://www.motopaskaitos.lt
grabavozas
Post by grabavozas »
Nu va, siandien pasiimsiu suremontuota deze (visi sinchrai pakeisti, ir dar uzhesio turetu nebut :roll: ). Tepala nupirkau mobil mobilube gx 80W-90. Tipo hi perfomace mineralke :D Kai surinksiu parasysiu kaip veikia..
Spoogen
Post by Spoogen »
OT: Kiek kainavo sinchru keitimas ishviso su darbu?
EG9 Ferio SOLD :(
'95 S14 SOLD :(
'02 WRX SOLD :(
'00 JDM STi Type-RA WRC Limited Edition Ver.6 (Nr. 948) SOLD :(:(:(
'02 EP3 Type-R :)
http://WWW.SUBARUDALYS.LT
grabavozas
sinchrai 750+450 (nauji + is dezes is Spade). Darbai kokia 500 (du kartus deze ardyta). Jei skaiciuot guolius tai dar 250 Lt. Jei skaiciuot savo darba, tai isvis neapsimoka :(
Spoogen wrote:OT: Kiek kainavo sinchru keitimas ishviso su darbu?
Spoogen
Post by Spoogen »
Reiskias reik sukalbeti malda pries miega dar del vieno dalyko...
EG9 Ferio SOLD :(
'95 S14 SOLD :(
'02 WRX SOLD :(
'02 EP3 Type-R :)
Giedrasas
Post by Giedrasas »
Gal kam bus naudinga info apie GL-5 naudojima greiciu dezej :wink: :
1. is FAQ: "What happens if API GL-5 gear oil is used in an API GL-4 gear oil application?
API GL-4 and API GL-5 products typically use the same extreme pressure (EP) additive system, with the API GL-5 having about twice the concentration of a API GL-4. In service, these additives become active under extreme load and temperature when the protective oil film can be squeezed away. EP additives work by forming wear-resistant compounds with the metal of the gear tooth surface. As the gears mesh, these compounds shield the gear teeth from direct metal-to-metal contact that would cause wear and damage to the gears. If too little of the active additive is present, proper protection would be compromised. Too much of this additive could cause excessive chemical corrosion of the gear surface. If an API GL-5 gear oil is used in a application where API GL-4 gear oil is called for, chemical corrosion of "yellow metal" components may occur, such as bronze synchronizers, brass bushings, etc. This may lead to shifting difficulties or shortened equipment life."
link'as: http://www.pennzoil.com/site/faq.html#q2
2. Diskusija SXOC:
http://www.sxoc.co.uk/vbb/showthread.ph ... ission+oil
-S14-
Fiend
Post by Fiend »
skamba lygiai taip pat kaip rasho apie xado veikimo principa..
omg!
Fiend wrote:skamba lygiai taip pat kaip rasho apie xado veikimo principa..
skirtumas TIK tas kad cia raso ne apie konkrtaus gamintojo produkta..o apie tepalo rusi, nepriklausomai nuo gamintojo..
ViR2ality
Post by ViR2ality »
dezhei supyliau net pats nepamenu kokio shlamshto, bet buvo pusiau sintetinis, nes ta diena nieko geriau neradau. O i diff'a suvarvinau RedLine 75w90 lsd oila, priesh tai buvo mobil1 lsd skirtas, tai galiu pasakyt, kad garsas visishkai pasikeite... ;)
Supra MKIII coming soon :)
Keliu tema, aktualu man.
Kaukia mano deze. kaukia "darbines" 1,2,3 pavaros. 4 ne, ir kazkodel 5. su sinchrais viskas tvarkoj.
kai isidejau ji nekauke, tepalas visalaik buvo sviezus, kaukimas tai mane nervina. ka daryt? pilt koki nors trinties modifikatoriu ar keist tepala i koki kita.
daba Neste, mineralinis
McPie
Post by McPie »
http://lubricantadvisor.valvolineeurope.com/
Transmission, manual 5/1 Capacity 2,4 liter
Use: Normal
Service intervals:
Check 40000 km / 24 months
SynPower TDL 75W-90
DuraBlend GL-4 75W-80
DuraBlend GL-4 75W-90
pamegink pakeist brand'a
RX-7 13B TII restauruojamas
brandas brandu, kodel tada 4 nekaukia, isvis tyli kaip niekur nieko :roll:
a todel kad ji tiesiogine ir nesuka jokiu papildomu "dantrachiu", kurie gali but pasideveje ir delto uzhia.
Re: tepalas transmisijai
Post by TaiTiek »
prikelsiu seną temą, gal jau esat išbandę daugiau tepalų rūšių ir t.t... Planuoju keisti greičių dėžės ir vlsd tepalus. Ką rekomenduojat?
paskutiniu metu pyliau valvoline pusiau sintetinius 75w90 - pigūs ir gerai veikia. jeigu norėsi išleist daugiau pinigų tai yra motul arba redline.
Post by TaiTiek »
ard wrote:paskutiniu metu pyliau valvoline pusiau sintetinius 75w90 - pigūs ir gerai veikia. jeigu norėsi išleist daugiau pinigų tai yra motul arba redline.
brangių turbūt nereikia...75w90 tai čia diff, dėžei ar abiem tinka?
kardanas
Post by kardanas »
koks tepalas geriau diskelinei blokiruotei
sintetinis ar mineralinis,abu su priedais blokiruotei
ar nesukt smegenu ir pilt Castrol Syntrax Limited Slip 75W-140
