BMW M21b24 Diesel Boost
SRitmas
Post by SRitmas »
if I were you, I'd modify the governor springs also to get more gut to the upper revs. Even though max power comes on 4800rpm on stock engine, the fuel amount is starting to reduce right after 3000rpm and engine feels somewhat like a rubber band. It's much nicer to have a governor that limits the injection after 5000rpm, so it pulls hard up like a gasoline engine.
"governor spring" Kaip ji valdo kuro kieky? Gal kas esate susidure su tuom?
Ir siaip reikia daugiau teorijos in LT :wink:
Re: BMW M21b24 Diesel Boost
Apie bmw dyzelių bombinimą čia daugiau info rasi -> http://forumas.bmwfan.lt/viewtopic.php?f=14&t=19296
vw killer
Post by vw killer »
Siaip jis is ten ir atejo ;)
SRitmas
Post by SRitmas »
:wink:
