Hey,
for sale
nissan s13 + HGK cage (certificated) - 2000EUR
HSD monopro coils - 600 EUR
For sale: nissan s13 + HGK cage / 1jz gte
Re: For sale: nissan s13 + HGK cage / 1jz gte
s14 rear subframe with AL bushes (eccentric for s13) and AL bushes for diff
S14 arm kin
Driftworks geomaster rear knuckles
JFP angle (kuckles, modified subframe(drive rack replaced) control arm, tense rod)
nissan s13 rear/front tower bar (933motosports)
nissan s13 front fenders bars
fiberglass front fenders +55mm
fiberglass rear fenders +55mm
fiberglass fron ventilated hood
fiberglass rear hach
rocket bunny duck tail (replica) have two off them used/new
nissan s13 dashboard
Diff 4.3 welded
Diff 4.3 locked
1jz gte
Poly/engine mounts for s schasse
VAG coilpac
Bochs 1000cc (new)
AEM fuel pump
AEM fuel pressure reg
Topfeed fuel
Topmount + Borgwarner turbo + braided lines + turbo bag
Turbobandit wg
ABC kit (adapter plate + flywheel + two disk tilton + pressure plate)
933motosports shiffter
ECU MS2
Mosul oil cooler +termostat + sandwich
Driftworks super cool radiator + spal(one off powerful one)
IC + ic pipes
Innovate wide band
for prices contact to
artursxozolins@gmail.com or whatsapp +37126820150
S14 arm kin
Diff 4.3 welded
Diff 4.3 locked
1jz gte
VAG coilpac
Bochs 1000cc (new)
AEM fuel pump
Topfeed fuel
Turbobandit wg
ECU MS2
IC + ic pipes
Innovate wide band
