S13 SR20DET FOR SALE.
Saneek
Post by Saneek »
Nissan 200sx s13 Sr20Det e85 ethanol, with rollcage, ready for Drift.
10900 Euro
Tel:+37129678920 (russian,latvian)
mail:saneek@inbox.lv
https://www.ss.lv/msg/ru/transport/cars ... fmxil.html
Engine:
Acl bearings
Arp Head stud kit
Arp Main bolt kit
ARP Rods bolt kit
TOMEI rocker arm stoppers
Cometic metal headgasket (1.6mm)
New nissan OEM oil pump
New nissan OEM piston rings
New nissan oem valve seals
Ebay aluminum oversized oil pan
Magnetic oil drain bolt
Poly engine mounts
Topmount exhaust collector
T3/T4 hybrid turbo(turboservisas. lt)
External wastegate
Apexi air filter
FMIC
Stainless steell custom piping
Stainless steell full exhaust(76mm from turbo)
TRANSMISSION:
BMW ZF gearbox (530D 2002)
Custom flywheel
Custom clutch kit
Custom aluminum shortshifter
MANAGEMENT:
Nistune Type4
860cc power interprise injectors
300ZX Z32 maf
Greddy Profec B Boost Controller
Knock gauge detonation(made in lithuania)
2X fuel pumps ( Bosch 044 motorsport +bmw 530 new fuel pump)
COOLING:
2X electric fans
Engine oil cooler
Oil sandwich plate with 2 sensors(pressure+temp erature)
SUSPENSION:
Custom coilovers
200sx s14 3.69 diff (welded)
Restored rear subframe with new aluminum bushings
Adjustable suspension arm kit( rear +front)
S14 200sx 5 lug kit hubs(front +rear)
Wheels spacers rear 45mm
Wheels spacers front 25mm
Driftworks offset rack spacers
Solid Billet Steering Shaft Rack Rod Bushing Spacer
Custom front knuckles for more angle
EXTERIOR:
BN SPORT bodykit
+50mm rear fenders
+50mm front fenders
Wheels ROTA P45 R18 rear 10J, front 9.5J.
Polycarbonate windows
INTERIOR:
Rollcage(sertificate)
New RRS 4 points belts with FIA homologation( 2021)
New RRS seat with FIA (2021)
Flocked dashboard
VDO gauges
Hydraulic hand brake
Racing battery switch off
Custom aluminum fuel tank (27L)
Custom stainless steel fuel catch cann
OMP steering wheel
Car working on e85 ethanol, boost 1.6 bar.
S13 SR20DET
Saneek
Re: S13 SR20DET FOR SALE.
Post by Saneek »
9900 EURO
S13 SR20DET
Saneek
Post by Saneek »
9000 euro :)
S13 SR20DET
