For sale: S14a 2JZ-GTE
Posted: 17 Nov 2014, 15:27
Car is DRIFT ready fully prepared for PRO level drift events! This car has Toyota supra 3.0l turbo engine with 730hp and 992nm!
Fully modified suspention and roll cage for drivers safety. FIA approved!
PRICE 26.000 euro
For more photos and info visit my web page http://www.petronisdrift.com
Or email me petronisdrift@gmail.com
Phone nmbr.: +37068517455
Nissan s14a
Engine: 730HP 992NM @ 4000rpm
Weight: 1148kg (car balance is 56% front, 44% rear)
- 2JZ-GTE Toyota Supra Engine
- Head porting, grinding, washing new valves and etc.
- New timing belt with New belt tensioner
- ARP Engine bolts
- ACL Bearings
- New Metal head gasket
- New piston rings
- BMW 3.0D gearbox (e46)
- NEW TILTON rally twin plate clutch
- 2jz/BMW Gearbox flange to fit bmw gearboxes (ABC Clutch)
- Custom made Flywheel (ABC clutch)
- Engine and gearbox bolt on pillows with mounts. (FITS ANY S CHASIS)
- TIAL 45mm WG
- Custom made T3 exhaust manifold
- Hybrid HOLSET HX40 Turbo with twin scroll 14cm2 hot end
- Turbo holder
- Exhaust T bolt clamp with up pipe
- Armoured turbo oil hoses and WG water cooling hoses
- Turbo oil return hose
- Custom made el. water pump system for best cooling
- Custom Made Intake manifold with 90mm afterarket throttle body
- Oil Catch tank with armoured hoses and fitings
- Greddy Sandwitch Plate
- Mocal Oil cooler with all hoses and fittings
- SIEMENS deko 1600cc fuel injectors
- Greddy Fuel Rail
- SARD Fuel FPR
- ACCEL ignition coils and MSD harness with MSD fittings
- KMS MD35 fully adjustable ECU, with all harness installation, all
sensors and all hardware mapped for this engine with all parts around.
- GTR style BIG INTERCOOLER
- All Silicone hoses
- KnN Air filter
- New NGK spark plugs
- Suspention
- APEX GEN2 Coilovers (spring rate F:10kg R:4kg)
- APEX control arms
- WISE FAB front angle kit (repainted)
- DMAX rear knuckles (dual callipers)
- Big Brembo brake kit 350mm front (ceramic brake pads)
- Dual alluminium Z32 brake callipers (ceramic brake pads)
- Brembo rear 280mm rotors
- R33 GTS drive shafts
- Custom made rear subframe to fit BMW differential
- Car comes with 2x differentials 2.94 and 3.44 ratios (now fitted 3.44)
- Interior
- Glass fiber S15 LHD pannel
- Greddy Profec B Spec 2 Boost controller
- APEXi el. gauges (water temp, oil press, boost)
- APEXi control unit
- AutoGage fuel lvl gauge
- Sard fuel press gauge
- Biltema 4" Tachometer
- Sandler 90mm dish drift wheel
- custom made wheel adaptor
- IRP Short Shifter
- IRP hand brake
- wilwood 6.25" brake cilinder
- sandler brake regulator'
- armoured teflon brake lines
- Davies Craig el. water pump
- APEX performance radiator (rear mounted)
- High quality water hoses for coolant circulation (Front -> Rear)
- JAZZ fuel cell 12 galons
- Custom made secondary fuell reservoir
- armoured fuel lines
- EARLS fuel line end fittings
- EARLS fuel filter
- MANN fuel filters
- QSP secondary fuel pump (fuel cell -> reservoir)
- 2x BOSCH motorsport 044 primary fuel pumps (reservoir -> injectors)
- OMP glass fiber driver seat (size L) with homo
- OMP WRC XL glass fiber passanger seat (size XL) with homo
- Sabelt 6 point racing belts (driver and passanger) with homo
- Full Roll Cage for your safety (FIA sport passport with homo)
- Custom made rear firewall (with cooling)
- Gel Battery
- Individual wiring
- Carbon fiber switch pannel
- Kill switch
- Fire extinguisher
- El. steering pump system
- Exterior
- Japan Racing JN12 rims (front 9JJ et+35, rear 10JJ et+20)
- ORIGIN Tadakidashi rear fenders (+70mm)
- Rocket Bunny rear duck tail
- Custom made glass fiber bonnet, bumpers, doors, side skirts, trunk, roof scoop, front fenders
- Plastic windows
- Plastic dual air vents (for rear radiator cooling)
- Glass fiber side mirrors
- SPARCO tow hook (front/rear)
- Lots of custom work done with shell. (car balance is 56% front 44% rear)
Youtube VIDS:
http://www.youtube.com/watch?v=Z0mhy-YK6jo&spfreload=10
http://www.youtube.com/watch?v=wQMC0nGbpVY&spfreload=10
http://www.youtube.com/watch?v=_bME1jBbmaw&spfreload=10
PRICE 26.000 euro
Nissan s14a
- ARP Engine bolts
- ACL Bearings
- New piston rings
- TIAL 45mm WG
- Turbo holder
- Greddy Fuel Rail
- SARD Fuel FPR
- KnN Air filter
- Suspention
- APEX control arms
- Interior
- IRP Short Shifter
- IRP hand brake
- EARLS fuel filter
- MANN fuel filters
- Gel Battery
- Individual wiring
- Kill switch
- Fire extinguisher
- Exterior
- Plastic windows
Youtube VIDS:
