Parduodu, s14. 23000lt. atnaujinta + foto
Engine:
Apexi power intake + hard pipe
t28 standart turbo + turbo elbow
braided oil & water lines
Apexperformance type2 FMIC
Mantoni ver2 bov
HKS silent Hipower exhaust
Horsham developments nissan doughterboard v2-0 + stage 1 chip
NGK 7s' spark plugs
ACT Heavy Duty pressure plate; organic sprung disc
Walbro 255LPH fuel pump
Nismo oil cap
D1spec 1.3 bar rad cap
Z32 fuel filter
Swoosh sandwitch plate
Nismo engine mount
Short shifter
Interior, Electronics:
Trust/Grex shift knob
Driftworks drift button
HKS turbo timer
Momo corse steering wheel
KNB steering wheel hub
D2 racing quick realease
Swoosh boost gauge
Swoosh oil press gauge
Swoosh oil temp gauge
Greddy profec B boost controller
R32 GTR front seats x2
Driftworks 4 point driver harness, homo 2013
aircon
Pioneer DEH p6100r 45w*4 head unit
pr. garsiakalbiai Kenwood kfc-1789ie, 220w peak, 4ohm, magnetas 285g
gal. garsiakalbiai Boston 160w peak, 40w nominal, 4 ohm
Suspension, brakes
Polyurethane exhaust hangers
Ksport coilovers 8/6 rate
adjustable tension rods
adjustable rear camber arms
adjustable rear toe arms
Apex perfromance rear subframe lower brace
steering lock spacers
Apex performance subframe locking collars
3.9 ratio welded diff or standart 3.6 viscous lsd
front brakes: z32 aluminium 4pot caliper with bracket, Brembo aftermarket 324*30mm discs, Reddot drift pads
rear brakes: z32 aluminium 2pot caliper, Brembo aftermarket 296*18mm discs, drum handbrake, new pads
Exterior
works9 body kit (painted green) or some JDM bodykit (painted black)
AVS model 5 rims. 8j et35, 9j et30.
despoilered
All arches rolled out
custom black corners
Kaina 23 000lt i kaina derybom galima susitart del masinos prieziuros klausimu, tolimesniu reikalu ar siaip demodinimo mazinant kaina.
8685 45797, Donatas, Vilnius
Re: Parduodu, s14. 25000lt. atnaujinta + foto
:arrow:
JurgisRA
Post by JurgisRA »
Anksciau buvo 22 000 berods.Kas iejo i tuos + 3000lt? :)
Post by TaiTiek »
keiciasi masina.
sudeta:
324*30 brembo aftermarketiniai diskai
reddot priekines kalades
z32 4pot aliumininiai suportai
gale 18" prieky 17"
naujas body
mantoni bov'as paskutines kartos
perdarytas duslius, kabo auksciau negu kebulas
isvalcuotos visos 4 arkos, truputi pataisyti kebuliniai reikalai
Nismo oil cap'as
HKS filtras pakeistas i Apexi
laikinai ikistas kaaz 2way su 3.9 perdavimu, renkamas 4.36. biski yra reikalu ten su istatymais
toj bus r32 gtr priekines sedynes abi.
gal dėl to..?
JurgisRA
Post by JurgisRA »
Aisku ;)
traukes reguliuojamos, ant stendo uzmesta, tepalai keisti, salonas kitas, isores reikalai tvarkyti, duslikas perdarytas, stabdziai kiti priekyje, daug didesni.
kaina smarkiai orientacine. per daug smulkmenu kad apibrezt. vietoj snekama bus kur kas ir kaip
Re: Parduodu, s14. 23000lt. atnaujinta + foto
23 000lt :roll:
