parduodu turbo calibra
gsi-s13
Post by gsi-s13 »
Re: parsiduoda turbo calibra
Cia motoro swapas ar turbintas atmosferikas?
MarcaZ
Post by MarcaZ »
Ir kaip ji "parsiduoda"? Cia moteris kokia?
Kas net ir moteris tik nuomuotis tegali...
gsi-s13
Post by gsi-s13 »
swapas tik idetas i lukshto kebula
sukasi tikrai neblogai
tau perkeltinem prasmem, jei tu to nesupranti, sako, jog tau deretu pakeisti temos pavadinima.
audriob
Post by audriob »
turbinines tik 4x4 buvo. Siaip nieko blogo ir NA uzturbintas, stumokliai kaltinukai standarte
e36 v12 m73
996 C4
996 TT
Staska
Post by Staska »
Tik be 4wd mashina shita nevazhioja ishvis (arba tik sausoj trasoj ir virhs 160 :D )
audriob wrote:turbinines tik 4x4 buvo. Siaip nieko blogo ir NA uzturbintas, stumokliai kaltinukai standarte
As nesu didelis opeliu specas, bet manau, kad klysti :mrgreen: . Is kur tokia info?
gsi-s13
Re: parduodu turbo calibra
Post by gsi-s13 »
su draginiu fiat uno lygia vaziuoja
Vyckius
Post by Vyckius »
gsi-s13 wrote:su draginiu fiat uno lygia vaziuoja
su tuo dyzeliniu? :lol:
gsi-s13
Post by gsi-s13 »
o tu ta dyzely padejai :?: :lol:
Vyckius
Post by Vyckius »
gsi-s13 wrote:o tu ta dyzely padejai :?: :lol:
nu ir pasnekejai ne i tema :roll: i klausima klausimu neatsakoma 8)
Tai kad Calibros turbo buvo tik 4x4:)
speidas cia turbut apie kaltinukus kalba
totto
Post by totto »
What makes the C20XE engine so good?
Over to you Steve. "It's one of the last production engines with a massive in-built tolerance for being tuned up. Most of the components are good for 250bhp. The rods can cope with that - the only reason we advise against it is that if the engine is over-revved it can cause problems. Even the pistons are fantastic. The original piston is a forged item - it's beautiful."
The entire bottom end of the C20XE is very strong, especially the crankshaft. "It's bomb proof," says Steve. "I've never seen one break. Even with an engine has run out of oil and the con-rod has disappeared out ot the side of the block the crank is still in one piece!" Such strrength would be useless if the C20XE couldn't produce the power and torque to exploit it, but the cylinder head is something of a mass-produced masterpiece, being designed by Cosworth engineering for GM/Opel's requirements. Packing decent-sized valves and ports and a highly efficient combustion chamber shape, the alloy 16-valve head will flow enough air to reach 230bhp before modifications are required.
Info: http://www.sbdev.co.uk/History_files/Hi ... epower.htm
donce
Post by donce »
zmones neivertina zodzio "forged" labai lengvai ji dalindami. net audi turbo stumuokliai,kuriuos visi vadina kaltinukais,realiai yra tiesiog stiprus cast,bet ne forged...
BNV. 696 whk
