Fully modified suspention and roll cage for drivers safety. FIA approved!
PRICE 26.000 euro
For more photos and info visit my web page http://www.petronisdrift.com
Or email me petronisdrift@gmail.com
Phone nmbr.: +37068517455
Nissan s14a
Engine: 730HP 992NM @ 4000rpm
Weight: 1148kg (car balance is 56% front, 44% rear)
- 2JZ-GTE Toyota Supra Engine
- Head porting, grinding, washing new valves and etc.
- New timing belt with New belt tensioner
- ARP Engine bolts
- ACL Bearings
- New Metal head gasket
- New piston rings
- BMW 3.0D gearbox (e46)
- NEW TILTON rally twin plate clutch
- 2jz/BMW Gearbox flange to fit bmw gearboxes (ABC Clutch)
- Custom made Flywheel (ABC clutch)
- Engine and gearbox bolt on pillows with mounts. (FITS ANY S CHASIS)
- TIAL 45mm WG
- Custom made T3 exhaust manifold
- Hybrid HOLSET HX40 Turbo with twin scroll 14cm2 hot end
- Turbo holder
- Exhaust T bolt clamp with up pipe
- Armoured turbo oil hoses and WG water cooling hoses
- Turbo oil return hose
- Custom made el. water pump system for best cooling
- Custom Made Intake manifold with 90mm afterarket throttle body
- Oil Catch tank with armoured hoses and fitings
- Greddy Sandwitch Plate
- Mocal Oil cooler with all hoses and fittings
- SIEMENS deko 1600cc fuel injectors
- Greddy Fuel Rail
- SARD Fuel FPR
- ACCEL ignition coils and MSD harness with MSD fittings
- KMS MD35 fully adjustable ECU, with all harness installation, all
sensors and all hardware mapped for this engine with all parts around.
- GTR style BIG INTERCOOLER
- All Silicone hoses
- KnN Air filter
- New NGK spark plugs
- Suspention
- APEX GEN2 Coilovers (spring rate F:10kg R:4kg)
- APEX control arms
- WISE FAB front angle kit (repainted)
- DMAX rear knuckles (dual callipers)
- Big Brembo brake kit 350mm front (ceramic brake pads)
- Dual alluminium Z32 brake callipers (ceramic brake pads)
- Brembo rear 280mm rotors
- R33 GTS drive shafts
- Custom made rear subframe to fit BMW differential
- Car comes with 2x differentials 2.94 and 3.44 ratios (now fitted 3.44)
- Interior
- Glass fiber S15 LHD pannel
- Greddy Profec B Spec 2 Boost controller
- APEXi el. gauges (water temp, oil press, boost)
- APEXi control unit
- AutoGage fuel lvl gauge
- Sard fuel press gauge
- Biltema 4" Tachometer
- Sandler 90mm dish drift wheel
- custom made wheel adaptor
- IRP Short Shifter
- IRP hand brake
- wilwood 6.25" brake cilinder
- sandler brake regulator'
- armoured teflon brake lines
- Davies Craig el. water pump
- APEX performance radiator (rear mounted)
- High quality water hoses for coolant circulation (Front -> Rear)
- JAZZ fuel cell 12 galons
- Custom made secondary fuell reservoir
- armoured fuel lines
- EARLS fuel line end fittings
- EARLS fuel filter
- MANN fuel filters
- QSP secondary fuel pump (fuel cell -> reservoir)
- 2x BOSCH motorsport 044 primary fuel pumps (reservoir -> injectors)
- OMP glass fiber driver seat (size L) with homo
- OMP WRC XL glass fiber passanger seat (size XL) with homo
- Sabelt 6 point racing belts (driver and passanger) with homo
- Full Roll Cage for your safety (FIA sport passport with homo)
- Custom made rear firewall (with cooling)
- Gel Battery
- Individual wiring
- Carbon fiber switch pannel
- Kill switch
- Fire extinguisher
- El. steering pump system
- Exterior
- Japan Racing JN12 rims (front 9JJ et+35, rear 10JJ et+20)
- ORIGIN Tadakidashi rear fenders (+70mm)
- Rocket Bunny rear duck tail
- Custom made glass fiber bonnet, bumpers, doors, side skirts, trunk, roof scoop, front fenders
- Plastic windows
- Plastic dual air vents (for rear radiator cooling)
- Glass fiber side mirrors
- SPARCO tow hook (front/rear)
- Lots of custom work done with shell. (car balance is 56% front 44% rear)
Youtube VIDS:
http://www.youtube.com/watch?v=Z0mhy-YK6jo&spfreload=10
http://www.youtube.com/watch?v=wQMC0nGbpVY&spfreload=10
http://www.youtube.com/watch?v=_bME1jBbmaw&spfreload=10
