Parduodu; Subas+stiprintuvas=400lt
Posted: 31 Mar 2009, 22:33
Subas CERWIN VEGA su firmoje daryta deze ;
12" Subwoofer
* Vega Maximum Thro w Suspension
* Rugged Die Cast Aluminum Frame
* Powerful Double Stack Magnet Assembly
* Titanium/Nickel Alloy Plated Diaphragm
* High Temperature Voice Coil
* Available in Single (SVC) voice Coil or Dual (DVC) Voice Coil.
* Designed for Sealed or Vega Ported Enclosures.
Frequency response:
20-500 Hz
Power handling:
RMS: 300 watts
Peak: 800 watts
Impedance:
•SVC models 4ohms nominal
•DVC models 4ohms nominal coil
DIMENSIONS
Mounting diameter:
11" (284 mm)
Depth:
6" (153.4 mm)
STIPRINTUVAS;
Crunch MXB-4125 4*80w RMS (jei neklystu) Filtrai,tiltuojasi ir t.t.
Kaina komplekto 400 lituku.
Kaunas 860185934
12" Subwoofer
Frequency response:
20-500 Hz
Power handling:
RMS: 300 watts
Peak: 800 watts
Impedance:
DIMENSIONS
Mounting diameter:
11" (284 mm)
Depth:
6" (153.4 mm)
STIPRINTUVAS;
Kaunas 860185934
