1200w 400rms 30cm
http://www.testfreaks.com/car-subwoofer ... kfc-w3011/
yra deze daryta pagal gamintojo reikalavimus, kaina 250lt, siek tiek derinama vietoje.
Taip pad yra prie jo stiprintuvas EVIR 800w, kaina 200lt
MH-2804 2 Ohms Rms Output Power: 4x140W ;4 Ohms Rms Outout Power: 4x80W ;4 Ohms Bridge Output Power: 2x220W;Distortion (THD): <=0.1%;Low Pass Crossover: 50Hz - 250Hz ;High Pass Crossover: 50Hz - 250Hz ;Bass Boost Level: (45Hz) 0dB - +6dB :
Frequency Response: 10Hz - 50kHz ;Signal to Noise Ratio: >95dB ;Stereo Separation: >50dB;Input Sensitivity: 0.4V - 10V ; Fuse Rating: 30A x 2 ;Dimansions: W260 x L430 x H60
4 kanalai po 140rms, sumoi 440rms
Viso komplekto kaina 420lt, Vilnius, Isamesne info PM arba nr. 860836624
