Modlist: Jarik Nissan S14a :)
Auto
1998 S14a SR20DET
87k KM
2011 Mods:
Engine:
CP Pistons 86.5mm/8.5:1
Eagle Chromoly Forged Rods
Tomei Metal Head Gasket 87.0 x 1.5mm
ARP Main Studs Set
ARP Head Studs Set
ACL Race Rod Bearing Set
ACL Race Main Bearing Set
ACL Thrust Washers Set
Moroso Upgraded Aluminum Oil Pan
NEW: OEM Complete Timing Chain Kit
NEW: OEM Oil Pump Assembly
NEW: OEM Complete Engine Gasket Kit
Megan Racing Light Weight Pulley Set
BC Camshaft 264/264 BC0201
BC Valve Springs BC0200
Tomei 13220R300 Rocker Arm Stoppers
BC Adjustable Cam Gears
Tomei Exhaust Valve Guide
Custom topmount Fuel Rail
Aeromotive Fuel Pressure Regulator
Bocsh 1600cc ijectors
Hibrid Turbo T4 ~GT40
Aftermarket exhaust manifold
Nira i3+ ECU
Greddy Profec B Electronic Boost Controller (radija)
100mm K&N Intake + custom pipe
Custom double plenum Intake manifold
Custom Exhaust manifold + Outlet Pipe
Exhaust custom 76mm
Intercooler FronMount 600x295x120 mm + custom pipe
Greddy TypeRS bov
2X Bosh 044 Fuel Pump + 2X Facet Silver Top low pressure fuel pump + QSP 3L resiver
ORC Clutch
Apex 54mm Aluminum Racing Radiator
Apex 11 inch electronic fan double
Oil Cooler kit (mix china + Greddy )
Suspension:
Apex Coils 10/8
Apex rear Control Arms
Apex rear Rods
Apex rear Arms
Apex rear Tension Rods
DW Lower Arm Front
DW Lower Arm Rear
DW Poly bushes (kit)
Maxx bigangle mod
DW Big Angle Tie Rods
Energy Suspension Polyurethane Steering Rack Bushing
Upgradet rear subframe with metal Inserts welded
Upgradet front subframe move to front 25mm Steering Rack
Circuit Sports Brake Lines
Front 315mm M3 brake disk + ProjectMu HC pads
Rear 294mm Z32 brake system + ProjectMu DriftSpec pads
Tanabe Sustec sway bars (Drift Spec) front,rear
Megan Racing Front/Rear Sway Bar End Links
Diff 2wai custom
fender brace custom
Power Brace front custom (Nismo copy)
Strut Bar front & rear custom
rear lower suspension brace custom
Inside:
Steering wheel Momo prototipo
Bucket Seat Sabelt Taurus XL
Bucket Seat Sabelt Titan XL
3" 6 point Race Harness Alium
Sparco FireWarrior mechanical extinguishing
Tomei shift knob
Hidraulic hand brake
Short Shifteris (Kinija)
RollCage Circuit-Drift spec FIA:)
Wheels
5Zigen FN01R-C BLACK POLISH
Front R17X9.0J ET15 - 2vnt
Rear:
5Zigen R17X10.0J ET12 -2vnt
Advan v2 R17x9.0 ET35 -2vnt
BBS R17x8.0 ET35 -4vnt
Lexus R18x8.5 ET35 -4vnt
Tojota R16x8.0 ET30 -4vnt
Nissan R16x6.5 ET35 -6vnt
Boost
0.9Bar - 310Ag / 385Nm http://www.per4m.lt/forum/download/file.php?id=2309
1.2Bar +E85 - 390Ag / 430Nm
1998 S14a SR20DET
87k KM
2011 Mods:
Engine:
ARP Main Studs Set
ARP Head Studs Set
Nira i3+ ECU
Exhaust custom 76mm
Greddy TypeRS bov
ORC Clutch
Suspension:
Apex Coils 10/8
Apex rear Rods
Apex rear Arms
DW Lower Arm Front
DW Lower Arm Rear
Maxx bigangle mod
Diff 2wai custom
fender brace custom
Inside:
Tomei shift knob
Wheels
Rear:
Boost
Apsivalei biski ?
Siaip tai ledova masina ir kuo tuoliau tuo geriau...viskas kaip ir paruosta didesniai sraigei.
taip apsivaliauPSI wrote:Apsivalei biski ?
taip liko tik power modai ir saugumo modai bet cia jau kitoi serijoi matyt
p.s. kaip sakant kita sezona
kita serija prasidejo
darom saugumo modus tvarkom kebula dedam lankus !
kas galetu paskolint vestuvus !! Doggy variantas kaip paviszdis: arba kas noretu susikoperot su manim to daigto pagaminime ir paskui ji pasimt nes as neturiu saligu kur toki griozda laikyt !!!
as tai galvoju ar butina abejus galus sujungti, gal tada netoks didelis griozdas gausis. Kazkada teko matyti verstuva, kuris prisisukdavo prie ratu stebuliu ir kaip vyris lenkdavosi. Ant tokio su dugnu irgi turetu buti patogu dirbti, bet vietos zymiai maziau uzimtu...
bet tada turi palikti pakaba, o virintan siules, skutant smalas taip iseina neprieisi prie daugelio vietu.romkasponka wrote:as tai galvoju ar butina abejus galus sujungti, gal tada netoks didelis griozdas gausis. Kazkada teko matyti verstuva, kuris prisisukdavo prie ratu stebuliu ir kaip vyris lenkdavosi. Ant tokio su dugnu irgi turetu buti patogu dirbti, bet vietos zymiai maziau uzimtu...
Abu galus ant vartytuvo nera butina sujungti.
Na bet ATOMBOY cia ziuriu teisinga linkme eina
Sveikas, as turiu ir zadu (tikiuosi) menesio begyje saviski nuleist ant ratu ir atiduot dazyt tai aparatas jau laisvas butu. pasuk kada prie progos Taucius
gut sukontaktosim, kaip tik busiu apsiardes jau viska !markss wrote:Sveikas, as turiu ir zadu (tikiuosi) menesio begyje saviski nuleist ant ratu ir atiduot dazyt tai aparatas jau laisvas butu. pasuk kada prie progos Taucius
o as jau buvau suplanaves kad irgi reiktu pasiskolint is Taucio Jarik jei ka labai neuztruk as kazkur uz menesio ar pusantro ardysiu masina
nu as jau pradejauRothman wrote:o as jau buvau suplanaves kad irgi reiktu pasiskolint is Taucio Jarik jei ka labai neuztruk as kazkur uz menesio ar pusantro ardysiu masina
lanku konfiguracija ! kas ka patars ? driftas-ziedas!
jei netrukdo priekyje peciukui/valytuvams tai dar kryziu priekyje tarp pagrindiniu lanku ir stakanu. Gale vamdziai bus vedami i amortiku tvirtinimo taskus?ATMBOY wrote: nu as jau pradejau
Kaip ten pas nissan prisisuka traversas gale prie kebulo? Darant ziedui vesciau ir i traversu tvirtinimo taskus vamdzius.
p.s. galinius pagrindinius vamzdzius stumk kuo toliau, kad galetum "foteli" max tolyn nustumti i gala.
p.p.s. kebulo siules pravirinsi? Jas reiktu pravirinti pries dedant lankus
Abieju kryziu apacioje dar deciau po skersini (atstoja rasporkes)
Edit: prisegu paveiksliuka kad aiskiau butu apie ka as..
- clio.JPG (22.41 KiB) Viewed 23315 times
Renault Clio Sport
Follow me on FB
Follow me on FB
1. taip daba kaip tik kede ideta kaip man reike pagal tai ir bandisiu det pagrindini lankanrvz wrote:jei netrukdo priekyje peciukui/valytuvams tai dar kryziu priekyje tarp pagrindiniu lanku ir stakanu. Gale vamdziai bus vedami i amortiku tvirtinimo taskus?ATMBOY wrote: nu as jau pradejau
2. taip kebula pervirinsiu priesh dedant lankus
3. del kriziaus tarp prekiniu stakanu (svarstau apie tai , pechiuko nebus po panele nieko neliks su valituvais matyt visada kazka galima sugalvot )
sutinku rasporke gale bushexe wrote:Abieju kryziu apacioje dar deciau po skersini (atstoja rasporkes)
nu visos paroditos shemos yra homologojamos nes duru apsaugas norejau daryt kitokias ...NISMO' wrote:O kaip su homologacijom visom?
ar busi be?
vamzdis ir schema turi atitikti minimalius reikalavimus, o jei daugiau, viskas ok.ATMBOY wrote:nu visos paroditos shemos yra homologojamos nes duru apsaugas norejau daryt kitokias ...NISMO' wrote:O kaip su homologacijom visom?
ar busi be?
seip ten reiketu pasidometi kaip juos homologuoti, vienas is variantu, yra susitarti su oficialiu lanku dejiku, kad jis savo kleima uzdetu.
p.s. kebula pries pervirinant, reiktu uzkrauti ant tampytoju stendo ir padaryti taip, kad matavimai butu iki 0.00
minimalus reikalavimai vamzdziu diametrui negalioja, jie turi buti tik tokie kokie nurodyti. Sieneles storis gali buti didesnis...
Jooooo, tokiu ir as noreciau
jau kelis matau ish europos Pro drifteriu susidejusiu tokius lankus !
S13.5 Driftworks S15 o kaip su homologacija ?
Melyni tai ziaurus tokie jau. As sau deciau (desiu kadanors ) beveik minimalios specifikacijos, kad dar homologuot butu galima (kazkur dar naminiam kompe turiu FIA minimaliu reikalavimu ta dokumenta, jei tingit kas patys ieskot galiu imest ). Kadangi i pro sporta ar rali vaziuot greitu laiku neplanuoju, tai manau, kad tie pvz melynieji lankai butu stipriai overkillas.
Volvo RWD - daily
Toyota RWD - race
Nissan RWD - fun
Toyota RWD - race
Nissan RWD - fun
