Modlist: vaikystes svajone 200sx
Postby aTofi » 03 Jan 2012, 00:55
Hi,
po ilgo ilgo laiko, visgi ikalbejau save parasyti modlista, gal kam bus idomu.
* Pirkau facelifted 200sx S13 (1994m) CA18DET - 2007m. vilniuje parvaryta is Italijos, pirkta aukcione kaip man sake, stovis buvo idealus, rudeles su padidinimo stiklu nerasi nei ant dugno nei prie stakanu, variklis be priekaistu, zodziu visiskas kaulas, kokiu reta. Eiline pardavejo istorija apie 1na savininka 51m ;) tiketi ar ne, nezinia..
Kadangi tuo metu apie masinas ne kazka tezinojau, sitas forumas padejo nenuklysti nuo doros kelio! Norisi padekoti senbuviams, kad netapau eilinis marozas uz vairo;)
* Pirkimo tikslas - tuo metu suzavejusi kylanti auto sporto saka driftas...
Su standartiniu CA maliausi geru pora metu, kol supratau kad jau atejo laikas swapui;)
Imestas SR'as - ir prasidejo zaidimai.... ;)
Engine:
* Walbro 255LPH
* Denso Iridium Spark plugs
* Apexi power intake
* IC (630x300x76) + pipes
* Nistune Type Board 4
* RPS Organic Clutch (350 lb/ft)
* Z32 Fuel filter
* Clutch Slave Cylinder
* Small battery
* Nismo Gearbox mount
* Exhaust + manifold Wrap
* Grid Boost Controller
* Q45 MAF
* Tomei Pon Cams (256/256)
* Trust T518Z turbo (ex 8cm2) + repair kit + new core ateiciai
* Japspeed manifold + elbow 3"
* Denso 2450 (850cc) injectors
* Engine damper
* 3" custom stainless steel exhaust
* Megan Racing Muffler 3"
* Oil cooler with remote oil filter
* Swoosh sandwitch plate
* Competition Clutch - Ceramic Stage5
* Competition Clutch - Ultra Lightweight Steel Flywheel ~4.5kg
Chassis:
* Apex Gen2 Coilovers 8/6
* GodSpeed ARB
* GodSpeed Front Tension Rods
* GodSpeed Rear Toe Arms
* GodSpeed Rear Traction Rods
* GodSpeed Rear Camber Arms
* Subframe locking collars
* Strut Brace front/rear
* Fender Brace
* IKEYA Formula Tie Rods
* Poly galinio tilto insertai
* Steering Shaft Spacer(saga)
* Goodrige brake lines (f/r)
* 5lug kit
* Front s14 Brakes + Brake pads(Kasyjama)
* Front brake disks
* KAAZ 2 way diff (4.36)
* 4x 20mm spacers
* Galines Driftworks reguliuojamos sakes
* Priekines reguliuojamos sakes
Interior:
* R32 seats
* Nardi wheel - on
* OMP deep dish wheel
* MOMO Hub
* Short Shifter
* Greddy 60mm - Boost(el.)
* Greddy 53mm - Oil Press
* Greddy 53mm - EGT
* Gauge pod 53mm
* D2 Snap-off
** Sparco 6/4 point harnesses
** Roll Cage (7 points)
** Hydro handbrake, AP cylinder + lines
*** Greddy Oil temp - ieskomas
Exterior:
* 4x WORK emottion XT7 R17 9j ET+17
* 4x ASA AR1 R17 8j
* 2x Sparco R17 8j
* 2x Origin DNA-01 R17 9.5j
* 2x ADR-95 SPARTAN R18 8.5j et20
* Wented lamp
Other:
* Removed ABS
* Fron new window + 'Champion' wipers =]]]
* ~2cm patraukta vairo kolonele i prieki
* neabejoju kad yra daugiau smulkiu daliu kurias pamirsau paminet.
Truksta iki pilnos laimes:
* smulmenu i salona
* kouki lempu
* bodykito
* isvalcuoti arkas
* EBC normalaus
* repaint'o
** - dalys yra - nesudetos.
*** planuojama artimu metu isigyti.
Rezultatas: 360ag @ 1.2bar
Daugiau nuotrauku, infos siek tiek veliau.
Re: Modlist: vaikystes svajone 200sx
Postby aTofi » 05 Jan 2012, 18:09
kamikazi
Postby kamikazi » 09 Jan 2012, 23:55
nice!!! tuoj lt nissanai skandinavija uzkariaus!
200sx 89 sr20det, T28, LSD, stage II, Big IC, FPR, OZ, kouki tails and apex gen2, soon M3/s14 brakes
Mirazh
Postby Mirazh » 05 Jul 2012, 19:50
Na perziurejau visus tavo klipus youtubej, ir nusprendziau, kad S13 200sx yra pakankamai grazus, anskciau norejau FC3S arba S13 coupe . Jei ne paslaptis, kiek sumokejai uz nissan stock'ini ?
Postby xargentum » 05 Jul 2012, 20:16
koks skirtumas kiek jis sumokejo uz ta nissana pries 5 metus? :)
Postby aTofi » 23 Jul 2013, 16:57
Padarytas issukimas pjovus stebule, idetos kazkokios reguliuojamos japan sakes, issisuka kazka apie 45*... Beliko susimapint is naujo, nes labai riebu, gaut tepalo temp gauga. Ir su gelezim bus baigta.. tada eis visi kiti papai, per dazymai, bamperiai ir t.t.
Kent
Postby Kent » 24 Jul 2013, 14:46
Nuostabu matyt S13 neatspardytą :)
mk2 golf 20vT on road
mk2 golf 24v Haldex on process :|
Postby aTofi » 24 Jul 2013, 16:55
atspardytas, lenktas galas ir t.t. :)
greit foto bus;)
Postby romkasponka » 24 Jul 2013, 23:29
galeciau palinketi stiprybes projekte ir supratimo ;)
Postby ard » 24 Jul 2013, 23:37
kai tiek laiko tęsiasi, tai stiprybė ir kantrybė = default
Postby spade » 24 Jul 2013, 23:41
Argi cia ilgai? :)
Paklausk manes, kada paskutini karta Honda vaziavo... 8) :lol:
e91
IbizaTDI [abandoned]
SV650S [crashed]
WRXwagon [stolen]
LTSR.LT [dead]
Postby romkasponka » 24 Jul 2013, 23:48
As manau kad spade itraukti i istorinius analus tai cia pareiga :D Bet visgi siais laikais tai jau patampa klasika, uz tai ir gerbiu ;)
Postby aTofi » 26 Dec 2013, 04:06
rezultatas:
http://www.youtube.com/watch?v=TfB0mklT3_c
ps: slegis 0.7bar, ebc sugedes lol
Postby romkasponka » 26 Dec 2013, 11:35
patiko operatorius :D
Postby ard » 19 Oct 2015, 11:22
patikrinau ar Macio vežėčios dar tinkamos naudojimui :lol:
https://instagram.com/p/8_MtDWmniD
Postby ard » 04 Mar 2016, 18:13
https://www.facebook.com/TeamBeat.lt/vi ... 958745163/
buvau pamiršęs papostint kaip atrodė D1Sport street lygos vilniaus kaukaro žiedo etapas iš Macio mašinos vidaus. 4.36 diffas pertrumpas generuojamam (dideliam ir lagovam) poweriui ir kai nėra gero sukibimo tai smarkiai daužo ribotuvą.
Return to “Projects & Modlists”
