Modlist: R32 GTR
Modlist: R32 GTR
1992 Nissan Skyline GTR
ARP head studs
ACL Race Series head gasket
ACL Race Series main & conrod bearings
ACL Race Series forged pistons & rings
Nismon N1 oil pump
HKS adjustable cam gears
Garrett 2860-5's turbos
Braided turbo cooling lines
Tomei turbo manifolds
Xforce 3.5" turboback exhaust
Xforce muffler with volume controle
Apexi Power FC ECU with hand controller
JJR coil packs
Turbosmart Eboost 2 boost controller
AWD/RWD Torque split controller
Nismo fuel pump
Nismo twin plate brass button clutch
Twin Turbosmart bov's
HKS gear knob
Stock R32 GTR wheels 16x8
413hp at the wheels
Ateities planai:
Isgauti kokius 600ag E85
Poly bushes
Coilovers
Brake upgrade
ARP head studs
Nismon N1 oil pump
JJR coil packs
Nismo fuel pump
HKS gear knob
413hp at the wheels
Ateities planai:
Poly bushes
Coilovers
Brake upgrade
GTR
When You Have AWD You Don't Replace Tyres, You Replace Boxes
Re: Modlist: R32 GTR
veiksmas, kaip supratau, Australijoj? Lt teks pamatyti?
- itariamasis
Australija, automobili vargu, vairuotoja gal...
Brake upgrade?
Brake upgrade?
Neseniai grizau is Lietuvos
Nebent pasidaryciau netiketai koks milijonierius , tai parsivesciau i Lietuva, bet kadangi toks nesu tai tikriausiai neteks
stabdzius noreciau brembo sudeti
GTR
Dar cia video toks
http://www.youtube.com/watch?v=WnQO3YENE6Y
http://www.youtube.com/watch?v=WG99jPaqC2Q
GTR
Atsitraukta saugiu atstumu, kad neikastu?RNN GTi-R wrote:Dar cia video toks
Taip buvo liepta
GTR
seniai berasiau sioje temoje, tai padarysiu sioki toki atnaujinima.
Siap nedaug pakitimu ivyko
Sudeti Tein coil
Rasporkes, prieki tomei, gale cusco
100mm intercooleris
900cc purkstukai
Nismo AFM's
Planuojama 600ag
BBS LM 18x10"
Ir kelios foto is mano kiemo
Isigijau dar viena
Sudeti Tein coil
100mm intercooleris
900cc purkstukai
Nismo AFM's
Planuojama 600ag
BBS LM 18x10"
Isigijau dar viena
GTR
Galima paklausti, kam 2 vienodos masinos ?:)
Buvo uz gera kaina, negalejau nepirkti, reikia prideti rankas siek tiek
Kai pabaigsiu tada parduosiu
GTR
Mes lietuviai. Australijoje irgi vazinejam tuo kuo LTU . Ford'us ir Holden'us palikim redneck'ams
Saunus aparatas . Reikia kada gyvai apziuteti Kaip sekasi vazineti su modifikacijomis? Ar turi Engineer certificate? Kam skirtas auto?
P.s. siuo metu pradedu rinkti 200sx S14a. Bandysiu megejiskai driftinti. Butu saunu kazka kartu sugalvoti
neturiu jokiu sertifikatu, vazineju ir tikiuosi, kad neisdefektuos
parasyk i pm, galetumem susitikti
GTR
linkejimus kylie perduokit
600hp nemazai rb26, kokie darbai ivyks su varikliu? turbu uzteks? tepimas? sausa sistema? patikimus ir ilgai grojancius 600 kad tureti reikia nemazai nuveikt.
Butinai
Siokie tokie darbai su varikliu jau ivyke, neseniai perrinktas, kaltiniai viduriai, turbinu uztektu iki ~ 700ag
aisku norint padaryt ilgaamzi varikli, pinigus galima leisti iki begalybes.
Yra teigianciu, kad ir stock variklis laiko 500ag, bet kaip ten yra nezinau.
Pats pravazinejau 2metus (gatvemis) su 400ag viskas laiko, tai ir dabar i lenktynes nesiruosiu, auto bus naudojamas gatvemis, tai gal laikis,
o jei ne tada darysim kazka geriau
GTR
Nelabai issivaizduoju kur tu su juo vaziuoji, bet NSW mentai tai stabdo kiekviena karta kai pamato bet koki modifikuota auto. Tuo paciu dar ir EPA (environment check) israso, o tada jau tenka beveik viska atgal i stock deti. Kitaip ragas.
Siaip saunus Skyline
siuo metu karta i dvi savaites isvaziuoju, bet buvo kai kasdien i darba vazinedavau, kolkas neturejau problemu su gtr
Kai turejau 2 GTiR du kartus buvo isdefektuoti, reikejo padaryti viska stock ir vaziuoti i patikrinima, o kai grizau namo vel viska atgal sudejau
GTR
o tai negalima gaut koki sertifikata, kad taip nebutu?nes manau,kad pilna ten visokio gerio is japsu ne standartuRNN GTi-R wrote:siuo metu karta i dvi savaites isvaziuoju, bet buvo kai kasdien i darba vazinedavau, kolkas neturejau problemu su gtr
- itariamasis
vytautaswink wrote:o tai negalima gaut koki sertifikata, kad taip nebutu?nes manau,kad pilna ten visokio gerio is japsu ne standartuRNN GTi-R wrote:siuo metu karta i dvi savaites isvaziuoju, bet buvo kai kasdien i darba vazinedavau, kolkas neturejau problemu su gtr
Diiego 222 wrote:Kaip sekasi vazineti su modifikacijomis? Ar turi Engineer certificate?
Reiketu gauti jam inzinieriaus sertifikata, kad galetu vazineti su savo tobulintais auto, ar sunku ji gauti Vilmantai?RNN GTi-R wrote:neturiu jokiu sertifikatu, vazineju ir tikiuosi, kad neisdefektuos
Galima, bet kai kurie mentai i tai nekreipia demesio.
Aisku paskui juos gali paduot i teisma.
As kol kas nesuku galvos del to, mano auto atrodo daugmaz standartas, nebent tureciau kazka tokio
GTR
Labai daug nesidomejau, nes kaip jau sakiau per daug nesuku galvos del to.itariamasis wrote:Reiketu gauti jam inzinieriaus sertifikata, kad galetu vazineti su savo tobulintais auto, ar sunku ji gauti Vilmantai?
Pvz buvo toks vienas mechanikas, kuris isdavinedavo tuos sertifikatus visokiems modifikuotiems auto, bet jis nekreipdavo demesio, kas ir kaip padaryta,
bet tai darydavo uz saibas, po kiek laiko mentai ji pariso ir nucancelino visus jo kada nors isduotus sertifikatus
O siaip jeigu rimtas mechanikas, kuris tuo uzsiima, tai gauti ta sertifikata yra gana sunku, nes viskas turi buti padaryta gerai, atitinkant au reikalavimus
Bet pvz auto technine bukle gali patikrint beveik kiekvienas mechanikas, kuris turi licenzija tai daryti ir vieni buna grieztesni negu kiti
As varau pas toki mechanika kuris patikrina ar signalas veikia, ar buferiai laikosi tvirtai, ar padangos geros ir kartais dar pravaziuoja
GTR
Na ir kaip jums gyvenimas policinej valstybej? Kaip manot, greit bausmes uz thought crime ives?
Viskas OK
Siandie visai netoli mano namu mentai buvo surenge reida, krate jiems itartinus namus sueme daug kriminalu
Tikiuosi pas mane neuzsuks
GTR
labai gerulis
blin taip ir noris i tau AU shaut i vergove kokia pasiimt koki JDM rare shit baudeja ir cruisint per dykumas
