Modlist: Rps 13 kamikaze's
kamikazi
Postby kamikazi » 01 Sep 2010, 19:37
Kamikaze's RPS13 modlist:
Engine:
SR20DET 286AG 315Nm (s14a)
FMIC Kit
FPR
Turbo T28bb (From s15) 0,8bar
3" stainless steel, exhaust system, 2 resonator + N1
BOV valve
NGK Iridium spark plugs (Heat7)
280L/h Fuel pump (From Japan)
Breaks:
Nissan skyline R34 break cilinder
Front: M3 break disks/s14 supports
Rear: stock
New break fluid lines, non ABS
Body:
Drift works 9 body kit (From Finland)
Kouki tail lamps (From Japan)
Ganador silvia mirrors (From Japan)
Home made rear 4,5cm fender
OZ Racing Futura Forged wheels R17 8J, 9J, 215/45
3cm spacers, with Subaru WRX STI bolts
Suspension:
Apexi Gen2 coilovers, spring rate 6/5
Adjusting suspension Arm Kit
Strut Bar (both)
Gauges:
Oil pressure in front of the engine
Oil pressure in middle of the engine
Turbo boost
Oil temperature
Voltage
Water temperature
Fuel/Air Ratio
Audio:
1,5KW
Problems left: dyno check
Pagaliau ir dokumentuose 2,0l!!! :)
Bolidas jau svedijoj! sanaudos 7,8l/100km
Aciu uz pagalba ir kantrybe visiem kas padejo ir palaike!!!
Valio!!!
Keiciam turba ir pardave pradedam kita projakta!
Klaidas istaisysiu veliau :oops:
200sx 89 sr20det, T28, LSD, stage II, Big IC, FPR, OZ, kouki tails and apex gen2, soon M3/s14 brakes
laimonas
Re: Rps 13 kamikaze's
Postby laimonas » 01 Sep 2010, 20:18
Galiniai sparnai gerai gavosi,tik dabar priekinius reiktu paplatinti :wink: .
Rolka
Postby Rolka » 01 Sep 2010, 21:56
Su visa pagarba jei jau sustri esam ir rasom angliskai tai darykim tai taisyklingai. Manau norejai parasyti ne breaks/break cylinder kas reikstu luziai/luzio cilindras o brakes ;)
07' BMW Z4 3.0si
ZWI
Postby ZWI » 01 Sep 2010, 22:27
kamikazi wrote:Kamikaze's RPS13 modlist:
Ganadori mirrors
Strotbars
interguru
Postby interguru » 01 Sep 2010, 23:01
visi tik pult nori o skaitet paskutini sakini:
---> SO-ON.TV <---
ZWI
Postby ZWI » 02 Sep 2010, 00:27
niekas nepuola, visi ramus...
tiesiog padeda autoriui surast klaidas ir tiek :P
slimshady
Postby slimshady » 02 Sep 2010, 13:42
Keiciam turba ir pardave pradedam kita projekta!
čia tu rimtai? :roll:
A2 ekonom
Audi TT quattro mk1
Postby aTofi » 02 Sep 2010, 19:09
Idomu, kokiu budu? pasidalinsi?
Galima geresniu fenderiu foto?
KDM
Postby KDM » 02 Sep 2010, 19:20
joa i man del fenderiu idomu ;]. beje pataisyk pavadinimas modlist:
seismo
Postby seismo » 02 Sep 2010, 19:58
del fenderiu visiem interesna cia :lol: as ir noriu :lol:
rps
Postby ATMBOY » 02 Sep 2010, 20:03
dedat antra metalini sparna ant virshaus ir shipsotes :D
kamikazi
Postby kamikazi » 02 Sep 2010, 20:10
ten kruva reikalu buvo su tuo sparnu, turiu fotkiu darbu telefone bet dar negaliu perkelt kolkas.
siaip medziagos kainavo apie 500lt plius 2 savaites darbo, nuo ryto iki vakaro, taip kad tikrai geriau nusipirkt ir prisikniedyt!!!
idejau kelias fenderiu foto dar!
DeeDee
Re: Modlist: Rps 13 kamikaze's
Postby DeeDee » 03 Sep 2010, 22:16
labai grazus nissanas.
Volvo S80 2.5 TDI 1999
Postby NISMO' » 04 Sep 2010, 01:31
seismo wrote:del fenderiu visiem interesna cia :lol: as ir noriu :lol:
taigi Japsupse pilna tu sparnu ORIGIN ar dar kokio bieso po 1klt
Pauliukas.
Postby Pauliukas. » 04 Sep 2010, 11:55
idomei ka padarei kad su fenderiais bako dangtelis lygiai su sparnu o neikrites i vidu? negi tiek molio dejai?
KDM
Postby KDM » 04 Sep 2010, 14:26
cia realiai ne fenderiai o prideti kiti galiniai sparnai ant virsaus. tai ir dangteli yra kur prisukt.
kamikazi
Postby kamikazi » 04 Sep 2010, 19:12
padariau stiklo audinio karkasa ir sulyginau su aboksidiniu spaklium, visai gerai gavosi, padarysiu kada foto. o orginaliu sparnu arkos tik issipjove
kamikazi
Postby kamikazi » 05 Sep 2010, 10:38
Rolka
Postby Rolka » 05 Sep 2010, 12:14
Tokius darbus uzskaitau :) pagarba, tik dropo dar biski truksta, bent prieky :)
07' BMW Z4 3.0si
artasz
Postby artasz » 05 Sep 2010, 12:14
po tiek darbu kam tu ji parduodi? ar jis buvo kuriamas su mintimi parduoti?
kamikazi
Postby kamikazi » 05 Sep 2010, 12:50
per brangi man masina, o ir be nissano gyvenimo planu pilna, bet negaves geros sumos neparduosiu. dropas bus veliau, reikejo juk kazkaip i kelta ivaziuot :)
kamikazi
Postby kamikazi » 24 Oct 2010, 23:07
snd ismokau sitaip
http://www.youtube.com/watch?v=a1GFmrjVMNI
aisku ne tokiu greiciu bet vistiek gavosi, du kartus dar pora sauliu ir panagu nebeliko ryt kitas dedam! ir laukiam penktad dyno atsakymo jei tik neuzsnigs ir bus galima davaziuoti...
4Black
Postby 4Black » 27 Oct 2010, 00:28
tikras kamikadzis, mokaisi :)
kamikazi
Postby kamikazi » 29 Oct 2010, 20:19
Dyno test: 286AG (7046rpm 196km/h 4gear) 315Nm 5098rpm
0,8bar
Butinai reikia sport ismetimo koliko arba bent jau performance downpipe!
kamikazi
Postby kamikazi » 29 Oct 2010, 21:44
Return to “Projects & Modlists”
Users browsing this forum: No registered users and 3 guests
