Modlist:
Fully built engine by RB MOTORSPORTS:
RB Motorsports gold engine covers
Trust Iridium 8# spark plugs
Greddy clear cam cover
Tomei Cams and Pulleys 260x9.15
Tomei kevlar timing belt
Tomei metal head gasket 1,2mmx87
Nissan OEM cam and crank seals
RB Motorsports Forged Pistons kit 86,5 and ring set
Block rebore to suit pistons
Nissan N1 Oil pump and gaskets
Tomei con rod set
Tomei con rod bearing set
Nissan OEM main bearing set
Dynamically balanced crank and flywheel
Trust sump baffle kit
HKS GT2530 Turbo kit
HKS uprated actuators
HKS Turbo elbow kit
HKS downpipe
HKS full exhaus kit
Nismo Injectors 800cc 6x
Tomei Fuel presure reguliator FPR
Tomei Fuel pump
Nismo Aif Flow Meters MAF 2x
HKS Racing suction kit
HKS Racing intercooler kit FMIC
HKS Super SQV kit 2x
RB Motorsports Oil cooler
Aliuminium cooling radiator
Silicone breather hose kit
Water hoses set
Apexi Power FC
TRANSMISSION:
OSG Twin Plate Carbon clutch
Short shift
Nismo rear LSD
SUSPENSION:
Ohlins coilovers
Adjustable tension rods, front anr rear camber arms
Hicas eliminator
R18 x 9,5
Brembo brakes
Ferodo DS2500 pads
OTHER:
Defi oil pres., turbo, ext. temp. gauges
Shift light
Blitz boost controller
Skylab torque split controller
External fuel pump bosch 044
Roll cage (FIA)
Sparco driver seat (FIA)
Sabelt second seat (FIA)
Sabelt belts (FIA)
