Modlist: Nissan 200SX rS13 SR'ed
UNeX
Post by UNeX »
Trumpa istorija: nupirkau ja pries ~6 metus is tonic'o po variklio kapitalinio. Per savo neismanyma is karto pora kartu prapuciau galvos tarpine, bet po to tai nebepasikartojo :) Nuo to laiko variklis nebebuvo perrinkinejamas (cia tiems, kuriems ca'skes nelaiko :wink: (pravaziuota ~50kkm). O toliau seke tobulinimai ir karts nuo karto kebulo darbai :mrgreen:
Engine
sr20det
custom t3 top mount ismetimo kolikas
Holset HX32
TIAL isorinis wg
armuota turbinos tepimo slanga
HKS 256/256 valikai
wide baffled sump
76mm exhaust, screamer pipe
Apex'i oro filtras
Z32 AFM
60mm throttle
Custom Cold Air Intake
Apexperformance FMIC
Apexperformance aluminium radiator
SPAL electric twin fans
Revotec electronic fan controller
Power enterprise 850cc purkstukai
Walbro 255lph kuro pompa
Bosch 044 kuro pompa
custom kuro atstoinikas
custom alsuoklynas
Nistune
HKS Turbotimer
HKS Boost controller
Uzpildytos variklio pagalves
Didelis kuro filtras
Liqui Moly Synthoil GT1 10W-60
Thermostatic oil cooler kit
Denso Iridium zvakes
Pakaba,vaziuokle
Apexperformance rose jointed rear camber arms
Apexperformance rose jointed rear toe arms
Apexperformance rose jointed rear traction arms
Apexperformance rose jointed front tc arms
Apexperformance coilovers 6/5 kg/mm
Whiteline adjustable front swaybar
Whiteline adjustable rear swaybar
IKEYA Formula vairo traukes
pastumta vairo kolonele
pervirintos stupicos
s14 priekines sakes, sutvirtintos
Poly subframe bushes
Front strutbar
Rear strutbar
Front lower brace
Rear lower brace
Solid steering bushing
Steering rack bushes
370z 6 speed gearbox
ACT Xtreme 6 puck keramikine sankaba
ACT Streetlite Flywheel
Armuota sankabos slangute
Panaikintas sankabos stiprintuvas
Nismo + uzpildyta greiciu dezes pagalve
Tomei 2way LSD, 3.9 ratio
Gram Lights 57C 17' wheels (front 7.5j, rear 8.5j)
Front 205/45 Toyo Proxes T1-R
Rear 235/40 GoodYear Eagle F-1
Front -2.8' camber, 0.06' Toe-in, 5.0' caster
Rear -1.0' camber, 0.08' Toe-in
Stabdziai
Armuotos stabdziu slangutes
Motul RBF660 4.1 race brake fluid
Suportai visi keturi aliuminiai Z32, nusmeliuoti, nudazyti, naujai perrinkti
S14 MBC
JDM stabdziu pusle
Panaikintas ABS
Tilton brake proportioning valve
Stabdziu diskai
Priekis M3 315mm Black diamond grooved
Galas Z32 296mm Black diamond grooved
Stabdziu kaladeles
Priekis Ferodo DS2500
Galas EBC red stuff
Interior
Sparco 325mm wheel
50mm steering hub
Ksport lopsys
Ksport begiai
Ksport 6 tasku dirzai
Oil pres gauge
Oil temp gauge
Water temp gauge
Drift button
Exterior
Sleepy eyes
Xenon 4300K
Tamsinti langai
Front bumper
Sideskirts
Panaikinta antena
Panaikintas galinio lango valytuvas
Homemade skaidrus posukiai
Perdazyta, juodas stogas
Misc
Akumuliatorius nukeltas bagazinen
Foto, Video: http://www.facebook.com/LetsDMotorsport
Some pics:
Re: Modlist: Nissan 200SX rS13 ca18det
uzskaitau !!
(dabar prie paraso gali parasyt, known result ;) )
Suo
Post by Suo »
vienas tvarkingiausiu (o gal net tvarkingiausias) LIETUVOJ darytas S13 ;) Uzskaitau
Todo2
Post by Todo2 »
+1 8)
rs13
mindish
Post by mindish »
Suo wrote:vienas tvarkingiausiu (o gal net tvarkingiausias) LIETUVOJ darytas S13 ;) Uzskaitau
Pritariu. Patinka toks 'clean look'. O ir prie variklio teisingos rankos pridetos, 6metai greziant yra visdelto daug :) geras pvz. visiem s13 savininkam. Tik bodykit'as man nepatinka, bet kaip sakoma del skonio nesigincijama :wink:
ar tik ne sitas nissanas prienuose pas meistriukus pabuvojes????nes spalva jau labai matyta :mrgreen: :mrgreen:
UNeX
Post by UNeX »
Aciu :) Bet zinantiems kebulo bukle, tai nemanau, kad galeciau prisiimt tokia nominacija :)
ramas wrote:ar tik ne sitas nissanas prienuose pas meistriukus pabuvojes????nes spalva jau labai matyta :mrgreen: :mrgreen:
sitas sitas :D
Edvukas
Post by Edvukas »
Hot !!! :evil:
klausyk ,o stabdziu diskai tikrai teisingai priekiniai sudeti????
Povilas666
Post by Povilas666 »
Aha ir man toks vaizdas kad juos pusem reiketu sukeist...
UNeX
Post by UNeX »
manau teisingai, o ir gamintojo buvo pažymėta kuris left kuris right
AdreNAL1naS
Post by AdreNAL1naS »
Povilas666 wrote:Aha ir man toks vaizdas kad juos pusem reiketu sukeist...
ne del grrozio gi stovi tie diskai :D
http://www.tunerwerx.com/catalog/images/d2brakes6.jpg ;) va pvz :)
kavenskas22
Post by kavenskas22 »
aga, ir kurios cia puses nuotrauka? :?
tng
Post by tng »
mano Rotora'os irgi taip ant Hondos atrode...
past [ '00 jzs161 Aristo Mk2 ]
present [ '02 e39 530d ///M ]
per trenirote atrode kad truksta Ag :( reik padoresnio turbako
nesikabinekit prei disku :) ten pagal gamintojo nurodymus ir ventiliacinius takelius viskas ciki :)
ten disko isorine dalis nuo ventiliacinio tarpo storesne uz vidine.
jop per varzybeles gan vargiai sukosi motoriukas
Raizo
Post by Raizo »
Saunus 13'ukas 8)
turiu klausima, ziuriu idetas intake velenelis ca16de, bet esu mates, kad deda ir ca18de pastarasis negeriau butu, jei nieko nemaisau pas ji ilgesnes fazes. O jei kazka jau nusnekejau, prasau pataisykit :)
ir dar, pas tave Mahle stumokliai, cia jie kaltiniai ar tik siaip kokios firmos, nes ieskojausi per google, kazkaip neradau as tokiu :)
200sx Rs13 90m.
dolphin
Post by dolphin »
Raizo wrote: ir dar, pas tave Mahle stumokliai, cia jie kaltiniai ar tik siaip kokios firmos, nes ieskojausi per google, kazkaip neradau as tokiu :)
Kaip tu ieskojai, kad ivedus i google visas pirmas puslapis vien tik apie stumoklius...
Raizo wrote:turiu klausima, ziuriu idetas intake velenelis ca16de, bet esu mates, kad deda ir ca18de pastarasis negeriau butu, jei nieko nemaisau pas ji ilgesnes fazes. O jei kazka jau nusnekejau, prasau pataisykit :)
ca16de ir ca18de yra vienodo lifto ir duration'o, jie skiriasi tik timing'u.
UNeX
Post by UNeX »
truputi atsinaujinom.
T28 + Z32 AFM = 310ag, 330nm
selmundo
Post by selmundo »
Jau geri ir rimti skaiciai CA'skei ;) Kiek anksciau buvo, kad visi sake, kad vangiai sukosi?
P.s. kodel numeriai tokie seni?
UNeX
Post by UNeX »
selmundo wrote:Jau geri ir rimti skaiciai CA'skei ;) Kiek anksciau buvo, kad visi sake, kad vangiai sukosi?
seni numeriai, nes sena masina :D
Anksciau buvo 260ag ir 330nm. Siaip dabar torko siek tiek daugiau turetu but, nes po paskutiniu nistune'o finetune'u nebesukta ant stendo, bet buvo dar ir degimas ankstintas ir misinys koreguotas.
Iver
Post by Iver »
Tema negyva, tačiau veiksmas tęsiasi:
Locked
