Modlist: Raketinis s14. XR'o zaislas
Engine:
Apexi power intake + hard pipe
s15bb turbo + turbo elbow
braided oil & water lines
Apexperformance type2 FMIC
Mantoni ver2 bov
HKS silent Hipower exhaust
Horsham developments nissan doughterboard v2-0 + stage 1 chip
NGK 7s' spark plugs
ACT Heavy Duty pressure plate; organic sprung disc
Walbro 255LPH fuel pump
Nismo oil cap
D1spec 1.3 bar rad cap
Z32 fuel filter
Swoosh sandwitch plate
Nismo engine mount
Short shifter
Interior, Electronics:
Trust/Grex shift knob
Driftworks drift button
HKS turbo timer
OMP steering wheel
KNB steering wheel hub
Swoosh boost gauge
Swoosh oil press gauge
Swoosh oil temp gauge
Greddy profec B boost controller (low 0.9; hi 1.2)
R32 GTR front seats x2
Driftworks 4 point driver harness, homo 2013
aircon
Pioneer DEH p6100r 45w*4 head unit
pr. garsiakalbiai Kenwood kfc-1789ie, 220w peak, 4ohm, magnetas 285g
gal. garsiakalbiai Boston 160w peak, 40w nominal, 4 ohm
Suspension, brakes
Polyurethane exhaust hangers
Ksport coilovers 8/6 rate
adjustable tension rods
adjustable rear camber arms
adjustable rear toe arms
Apex perfromance rear subframe lower brace
steering lock spacers
Apex performance subframe locking collars
3.9 ratio welded diff/4.36 ratio welded (standart 3.6 viscous lsd)
front brakes: z32 aluminium 4pot caliper with bracket, Brembo aftermarket 324*30mm discs, Reddot drift pads
rear brakes: z32 aluminium 2pot caliper, Brembo aftermarket 296*18mm discs, drum handbrake, new pads
Exterior
Works9 style body kit
Unknown JDM body kit
Origin DNA01 17x9.5J et15 x4
Dunlop sportmaxx 225/45 + 245/40
18x8.5j et20 x2
despoilered
All arches rolled out
custom black corners
Masinos esme but pilnai street driven fun/drift automobilis, nerekiantis ismetimas, saldantis kondicionierius, grojanti muzika, visi veikiantys elektros prietaisai ir t.t.
Jis neturi but tas iprastas nissanas kuri visi prate LIETUVOJE matyt, tiek motoro skyriuj, tiek salone, tiek isorej. aisku kosmosu cia neprigalvosi, finansai finansais.
Dar truksta keliu modu kad galeciau vaizuoti savo stilium, kolkas tenka taikytis pvz prie minkstos dezes pagalves, dideles eigos shifterio. pagaliau atejo noras isbandyt short'a, nors niekada nemegau ju.
reik iisdet 4.36 diff'a, truksta sniurinimo 3 pavara kaip noretusi.
galines isvertimo ir suvedimo traukes.
Jei prisiversiu dar pagimdysiu kazka lengvo su issukiu, vaziuojant poroj su rimtesnem masinom truksta jo.
Bet siaip masina is esmes baigta iki tokio lygio kokio ir norejau.
pagal ideja dabar turetu but netoli 300ag @ 1.2bar. ant stendo dar nebuvau uzmetes, lauksiu kokio dyno day ar dar kazko.
padarysiu prie progos begejimosi video iki 260km/h (uzdaram kely) ir dar keleta drift video.
kulturnai pasleptas ebc
Dvarkiemio treniruotes
Po keleto tokiu vaziavimu buvau ismestas is treniruotes uz chamiska vazinejima trasoje teko atsiprasyt ir kita karta vel vaziuot dalyvaut
Bulviu puta
Kacergos fun'as
Mantoni ver2 bov
NGK 7s' spark plugs
Nismo oil cap
Z32 fuel filter
Nismo engine mount
Short shifter
HKS turbo timer
OMP steering wheel
Swoosh boost gauge
aircon
Suspension, brakes
Exterior
18x8.5j et20 x2
despoilered
Bulviu puta
Kacergos fun'as
Re: Modlist: Raketinis s14. XR'o zaislas
dar pamirsau juodi gabaritai
keiciasi masina.
sudeta:
324*30 brembo aftermarketiniai diskai
reddot priekines kalades
z32 4pot aliumininiai suportai
gale 18" prieky 17"
naujas body
mantoni bov'as paskutines kartos
perdarytas duslius, kabo auksciau negu kebulas
isvalcuotos visos 4 arkos, truputi pataisyti kebuliniai reikalai
Nismo oil cap'as
HKS filtras pakeistas i Apexi
laikinai ikistas kaaz 2way su 3.9 perdavimu, renkamas 4.36. biski yra reikalu ten su istatymais
toj bus r32 gtr priekines sedynes abi.
dabar ziurint i ratus kurie turi normalius dydzius atrodo kad jie kaip standartai lenda
Isorej liko vienas modas.
DRF 007 nu ir dar biski rastafkiu primetyt ir dropa sureguliavus ant suvedimo stendo nulekt.
laukiam fastlap'o. nusidauzt nuo vaizdo. woohooo!
sudeta:
gale 18" prieky 17"
naujas body
Nismo oil cap'as
Nu va - dar vienas puse desros s14 gimsta GERIAU nei tavo rudziu buveine R32...
gal ir jo bet motoro skyrius su sr'u uzpisa noreciau rb25. bet yra kaip yra.
Muhahaha ;] DRF bro ;]
- IMGP1526.jpg (98.11 KiB) Viewed 12385 times
ka matuoja tas dačikas prie isiurbimo kolektoriaus, toks labai panašus kaip ant šildymo katilu buna
matyt katilo slegicooler wrote:ka matuoja tas dačikas prie isiurbimo kolektoriaus, toks labai panašus kaip ant šildymo katilu buna
kuro slegis. ikirtau moda. verkiu keliuke galit spet kurio kampo neliko
http://speedhunters.com/archive/2010/05 ... angan.aspx
as uz vairotojo puses preki
p.s. ten gi uzdarytas keliukas rodos
Eina sau, pirmas S14 kuris man pradejo patikt, o jau sup**ai
BMW 535TT( http://www.drifter.lt/forumas/viewtopic ... 3&start=40 )
BMW 725 tds
BMW 725 tds
da nieko ten nebuvo, preikinis bamperis paluzo ir viskas neverkit. susitvarkys skardos vietose, lempos irgi stiklo audinis luzo, big deal
O davai tu to priekinio bamperio netaises pasieskok kokio rocket bunny (style)
ne. jau sutvarkyta. pasiruosineju fastlapui sert
mastau ka daryt su diffu, praeita kart lekiau su 3.9, atrode viskas ciki, bet su masina bedu buvo, negalejau iki galo tempt.
4 ir taip nesuks, 300ag nelabai velka.
det 4.36? bus per trumpa 3 ir 4 vistiek gali netempt. vel levai ku daryt...
palik ta 3.9
4.0.6 MAXIMUM maziausia! poto nepavaziuosi letose trasose
dejau as ant tu letu trasu, diffu kruva guli. man aktualiausia kacerga dabar.
sian padirbejau su fotiku, noriu pakilt su balionu per fastlap'a
ryt prasideda galutiniai checkai, tikrinimai, ir paskutiniai modai pries kacerga.
va sutaisytas damage'as per15 minuciu
nu va jau Xr'o style lupenos pozymiaj
p.s. arkas taip baisiai valcavai su kuo ? jau antra tokia mashina matau tavo darbas ?
as nevalcuoju. o sitas sparnas nuo smugio susiraite.
heh dabar nori nenori turesi facebook'e registruotis - ten reikia kelti foto ir patarciau paskubeti, reikes kad ~100zmoniu paspaustu ant tavo fotkes "patinka" :>XR_as wrote:sian padirbejau su fotiku, noriu pakilt su balionu per fastlap'a
Buferis gavosi kova style. Pats tas kacergai
- Marchius LT
OT: Garažas įkeltas automanų teismui. XR_ai - tau reikės labai savo chebra sumotyvuoti, kad per rytojų iki 17 val. į lyderius išsiveržtum!
Foto čia: http://www.facebook.com/album.php?aid=2 ... 173&ref=nf
http://www.svenciubites.lt - Svenciubites.lt
padedam xr`ui ;] palaikinta
46 like, sparciai vejasi. Must GO!KDM wrote:padedam xr`ui ;] palaikinta
idomu kaip i baliona s14 savo isikels
