Tepalo slegio gauges pajungimas i s-13ta
DnB
Post by DnB »
Sveiki tai va noriu pasijungti tepalo slegio gauge i s13-ta, turbo slegio pasijungiau cia aisku vyskas,bet kur ir kaip ten reikia pasijungti ta tepalo gauge ir ta davikli. ? :)
Nissan s13(91m) sold
Honda cbr1100xx sold
Yamaha fzr 1000 (95)
BMW 528 E39 (01)
Re: Tepalo slegio gauges pajungimas i s-13ta
dėk sandwich plate'ą ir į jį įsuk daviklį.
DnB
Post by DnB »
gauge Vdo ,daviklis taip pat
BMW 528 E39 (01)
DnB
Post by DnB »
ard wrote:dėk sandwich plate'ą ir į jį įsuk daviklį.
Gerai tai reiskiasi reikia pirkti dar ta vadinama buterbroda :)
BMW 528 E39 (01)
ince
Post by ince »
Nebutinai. Galima isukt i standartinio daviklio vieta. Dar vienas dalykas gerai su VDO, kad galima ir lempute ,ir gauge pasijungti nuo jo vieno.
DnB
Post by DnB »
O tais sriegiai ir diametrai man ten tiks jei standartine vieta isuksiu ji, ?gal kam teko deti Vdo,cia jis senesnes kartos
BMW 528 E39 (01)
DnB wrote:O tais sriegiai ir diametrai man ten tiks jei standartine vieta isuksiu ji, ?gal kam teko deti Vdo,cia jis senesnes kartos
Lambada sensor M18 x 1.5
Oilfilter 3/4" x 16g BSP
Head to exhaust manifold studs M10 x 1.25
Turbo elbow studs (3 of them) M10 x 1.25, note that the part of the stud that is screwed in the cast elbow is a regular M10 x 1.5
Turbo water feed banjo bolt(turbo side and engine side) M14 x 1.5
Wheelstuds M12 x 1.25
Oilpressure sender 1/8 x 28g BSPT
Dashboard watertemperature sensor (with one wire)M12 x 1.25
ECU watertemperature sensor (the one with two wires) M12 x 1.5
Turbo oilfeed
Thanks to Ben at Hosesolutions for these precise details:
turbo side: 7/16JIC X 24tpi
engine side (elbow): S13 is M12 x 1
engine side (banjo): S14 is M12 x 1.25
engine side (banjo): S15 is M12 x 1.25
S13 Turbo oilfeed elbow
Thread in engineblock 1/8 x 28g BSPT
Thread in elbow M12 x 1mm
Copyrait @ SXOC.COM http://www.sxoc.com/vbb/showthread.php?t=64002
DnB
Post by DnB »
:) :wink:
BMW 528 E39 (01)
as i s13 vdo susidejas..bet dejaus as "sumustini" kadangi dar ir tepalo temperaturos pasijungiau :)
DnB
Post by DnB »
O kur sumustini pirkaisi?
BMW 528 E39 (01)
JustDonis
Post by JustDonis »
cia ir man idomu kur pirkai ir kiek mokejei? :)
RS13 ca18 >>> RPS13 :)))
pirkau tai is forumiecio nissanpower nes jis dalim savo s13 buvo pazeres :)
O seip is gauges.lt pirktas buvo :)
